437
OxygenOS 11 Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. hemantkagh
    Froyo Jan 25, 2021
  2. Keerthi@1406
    Cupcake Jan 25, 2021
  3. 9ior
    9ior , via OnePlus 7 , Jan 25, 2021 :
    This open beta 11 presents bluetooth errors, I can't connect to certain devices. I recommend you to wait for stable version. I am returning to android 10 through downgrade. Regards
  4. Vicky2209
  5. S1540987544556
    Froyo Jan 25, 2021
    S1540987544556 , Jan 25, 2021 :
    Garry garvit
    How cannot be it be usefull. Its just work when you receive notifications. Also it works perfectly fine in oneplus 7 also.​
    It would be more useful if it flashed for a set amount of time after notification, say 5 mins so you can see you have a notification with screen off. I do this with an app, AODnotify. Until we get the OS 11 full AOD.
    yashu0069 likes this.
  6. Sourav._.Pradhan
    Gingerbread Jan 25, 2021
    Sourav._.Pradhan , via OnePlus 7 Pro , Jan 25, 2021 :
    Yes but only when bluetooth device is not connected when bluetooth is connected it doesn't disconnects
    akks and yashu0069 like this.
  7. Sourav._.Pradhan
    So it's only wifi which causing reboot in ur device?
    X1568202271558 and yashu0069 like this.
  8. AJsurya
  9. H1576047488679
    Donut Jan 25, 2021
  10. rcaldejr
    Eclair Jan 25, 2021
    rcaldejr , via OnePlus 7 Pro , Jan 25, 2021 :
    I'm having an issue where I cannot answer incoming calls. I've noticed that this is an issue on the 8 series, but haven't seen it mentioned for the 7 series. If anyone knows a workaround, that would be awesome. Otherwise I'm forced to downgrade because of work.
    Everything else is working very very well for now on my end. Slightly faster battery usage than 10 stable, but that's all I've noticed for now.
    V1601087196681 likes this.
  11. G_Vijay_Sankar
    DSPRY likes this.
  12. srangu
    Froyo Jan 25, 2021
  13. Anees3867
  14. akks
    KitKat Jan 25, 2021
    akks , Jan 25, 2021 :
    Read the opening post
  15. akks
    KitKat Jan 25, 2021
    Shalin05 and V1570000338270 like this.
  16. akks
    KitKat Jan 25, 2021
    Restart your device. Clear cache
  17. akks
    KitKat Jan 25, 2021
    What exactly is the issue!?
  18. rcaldejr
    Eclair Jan 25, 2021
  19. srangu
    Froyo Jan 25, 2021
    srangu , via OnePlus 7 Pro , Jan 25, 2021 :
    Sorry I don't know. Thanks for the info.
  20. akks
    KitKat Jan 25, 2021
    Why, are you busy?
    Without explaining more, can't help
