458
OxygenOS 11 Open Beta 1 for the OnePlus 7T and OnePlus 7T Pro
  1. Kunalmakin
    Eclair Jan 25, 2021
    Kunalmakin , via OnePlus 7T Pro , Jan 25, 2021 :
    Installed it two times already and cleared the cache also and restarted it too
  2. Neitred , via OnePlus 7T Pro McLaren Edition , Jan 25, 2021 :
    Nice to read this. But if you really need help after reading, it will be a question that will be understandable. And the we are happy to help. 🤗
  3. Neitred , via OnePlus 7T Pro McLaren Edition , Jan 25, 2021 :
    Well I must say that Telegram is not working either now. So it's only Signal. Let's wait how quick they update their apps.
  4. Kunalmakin
    Eclair Jan 25, 2021
    I bought it few days ago and installed the beta version that day only and when I felt it was having some problems I hardware reseted it and again installed the beta version
    and battery is taking 1.5 hrs to 2 hrs to charge and discharges in 3.5 hrs to 4 hrs with normal usage
  5. AndroidSword
    Cupcake Jan 25, 2021
    AndroidSword , via OnePlus 7T , Jan 25, 2021 :
    So as a follow up to my last post in which I showed the charging speeds of OB1, here I am back with the battery life (or battery backup, as some used to say).
    Settings/Configs:
    WiFi: Always On
    Bluetooth: Always On
    Ambient Display: On
    Refresh Rate: 90Hz
    Haptics: Fully On and set to strong
    Auto-Brightness: On
    For the first beta, 5.5 hours of screen on time is pretty good, and this is after this device like 8 months or so old.
  6. Aaron2017
    Lollipop Jan 25, 2021
    Aaron2017 , via OnePlus 7T Pro , Jan 25, 2021 :
    Yeah,happy to help for sure,that's what this thread is for.but so far 90% of my responses would have been,READ people,READ.
  7. Aaron2017
  8. kcdominates
  9. c_harish87
    Eclair Jan 25, 2021
    c_harish87 , via OnePlus 7T Pro , Jan 25, 2021 :
    I updated my OnePlus 7T Pro Android 11 Open Beta 1 and one of the bugs I am encountering is that the WiFi and Mobile data connection is not stable at all and keeps on disconnecting frequently. This was not the case earlier. Very worst update. Lot of bugs. Please fix this problem next beta update
  10. Graham_rus
    Graham_rus , Jan 25, 2021 :
    Hello, from time to time the swipe from the bottom to the center of the screen stops working, the reboot helps. please fix
  11. Neitred , via OnePlus 7T Pro McLaren Edition , Jan 25, 2021 :
    Was it OTA or did you install it manually?
  12. Neitred , via OnePlus 7T Pro McLaren Edition , Jan 25, 2021 :
    If it's a question that has been asked for more then 100 times....then it's a READ! The problem is that some people always go to the last post before they post instead of reading the posts before. It's almost spam.
  13. Kunalmakin
    Eclair Jan 25, 2021
  14. Deepak Joshi S
    Deepak Joshi S , via OnePlus 7T , Jan 25, 2021 :
    Same here too
    AndroidSword likes this.
  15. Karan_Murthy
    Gingerbread Jan 25, 2021
    ombatijack likes this.
  16. Kunalmakin
    Eclair Jan 25, 2021
  17. SudhirRPatra
    Froyo Jan 25, 2021
    SudhirRPatra , via OnePlus 7T , Jan 25, 2021 :
    It is working on 7T too.
