457
OxygenOS 11 Open Beta 1 for the OnePlus 7T and OnePlus 7T Pro
  1. RakshitYadav3232
    Cupcake Jan 26, 2021
    RakshitYadav3232 , via OnePlus 7T , Jan 26, 2021 :
    Been using it for a quite a time now, it's fluid and smooth. Got a couple bigs abd glitches to report and also got a quick reply on the submitted report.
    Really great
  2. beingsharma2 , via OnePlus 7T Glacier Blue , Jan 26, 2021 :
    Atleast improve some functionality, it should not flicker, it should show some notifications requires more light etc.
    This a user consider as bug 🐛.
    It should fix in Beta 2
    Thanks.
  3. McJader
    Marshmallow Jan 26, 2021
    McJader , Jan 26, 2021 :
    I am a user
    A bug is when there is a fault in the software
    In this case, a simple google search would've told you that slow motion requires good light
    You can however request a feature, where the AI tells you to move to a brighter place for slo-mo
    And you can request it here
  4. Boomer112
    Eclair Jan 26, 2021
    Boomer112 , via OnePlus 7T , Jan 26, 2021 :
    Well, it's still not a bug 🤣 Slow motion ACTUALLY needs good lighting, etc.
  5. beingsharma2 , via OnePlus 7T Glacier Blue , Jan 26, 2021 :
    If you are a user then it should be your point also regarding slow-mo.
    Isn't it instead of suggestion?
  6. McJader
    Dude I know that slo-mo requires good lighting, so I don't need the AI to tell me
    You need the feature, so I told you to request it
    aaronpe likes this.
  7. Veeraprabhahara
  8. beingsharma2 , via OnePlus 7T Glacier Blue , Jan 26, 2021 :
    Mate u know that's good you don't need AI to tell you, think of in general for public
    It would be better if AI notifies.
  9. Boomer112
    Eclair Jan 26, 2021
    Well, Yeah. That would honestly be a great feature that tells you that slow motion needs good lighting.
    beingsharma2 likes this.
  10. md.dhalech , via OnePlus 7T Glacier Blue , Jan 26, 2021 :
    Yes that correct but bro i tried signal for bubbles chat but in that also it's not working
  11. G1509700618638
    Froyo Jan 26, 2021
  12. QuintinG
    Eclair Jan 26, 2021
    QuintinG , Jan 26, 2021 :
    That is a stellar response :) lol
    McJader likes this.
  13. oxy|GEN
    oxy|GEN , Jan 26, 2021 :
    I had the same issue on a 7T.
    Phone app kept force closing, WiFi and cellular didn't connect.
    The new beta for the Nord had fixed an issue with "2nd SIM cannot be set to primary". As I am sporting two SIMs I could see this being the same issue on the 7...
  14. Tommolo
    Eclair Jan 26, 2021
    Tommolo , via OnePlus 7T , Jan 26, 2021 :
    Everything is good so far. I have zero bugs, the phone is responsive as it should be. The only issue I'm experiencing is a bit of stuttering when I'm typing with the keyboard when the phone has been on for a few days. A reboot just works fine.
    Battery life is also good, I always got more than 6 hours of SOT with WiFi.
    To anyone experiencing bugs I suggest a clean install, that's what I did when I downloaded the beta.
    Sameeh Kotkata likes this.
  15. McJader
    So tell them!
    They won't know what the general public wants until the general public tells them!
    And how can general public tell them?
    Through here
    ghostofcain and aaronpe like this.
  16. McJader
  17. WFred
    Froyo Jan 26, 2021
    WFred , via OnePlus 7T , Jan 26, 2021 :
    It has to be saved in the main storage, not downloads, and end with .zip for Lucas upgrade to see the file
  18. WFred
    Froyo Jan 26, 2021
    from the backup you (hopefully) made prior to installing a beta release; otherwise...
    Unless there is some reason you HAVE TO HAVE the absolute latest OS, wait for the stable. I'm in no rush.
    ghostofcain likes this.
