448
OxygenOS 11 Open Beta 1 for the OnePlus 7T and OnePlus 7T Pro
  1. NITHIN_davE
    Cupcake Jan 27, 2021
    NITHIN_davE , via OnePlus 7T , Jan 27, 2021 :
    Cannot find pocket mode after new update.
    As a result automatically calls are being dailed and music is changing when in pocket.
    Please bring back the pocket mode in the next update.
    Lockdown is not a feasible option as i have to again unlock the phone by providing the pin even after connected to smart lock wearables.
  2. X1570717455902
    Gingerbread Jan 27, 2021
    X1570717455902 , via OnePlus 7T , Jan 27, 2021 :
    About the status bar maybe you turned you disabled status bar on locksreen
    Plz check-in lock screen and hit the gear icon there you can find it
  3. Mohan Reddy Y V M , via OnePlus 7T Glacier Blue , Jan 27, 2021 :
    Hmm
    V.I.C.K.Y likes this.
  4. JiyaDeenRashi
    Donut Jan 27, 2021
  5. OmriCalifa
    Froyo Jan 27, 2021
    OmriCalifa , via OnePlus 7T , Jan 27, 2021 :
    Ok , i promised a screenshot of problem number 6 (with the notification) so... Here it is :
    Actually, as ypu can see , i got a conversation notification , and there is a silent notification and the regular notifications panel is there but empty . It's a little bit anoying so it have to be fixed !
    shettychadda likes this.
  6. McJader
    Lollipop Jan 27, 2021
    McJader , Jan 27, 2021 :
    Make sure to follow all these steps exactly
    F1580154499793 likes this.
  7. OnePlus_7T
    Froyo Jan 27, 2021
  8. Last edited: Jan 27, 2021
    KeeBaud and ghostofcain like this.
  9. Neel_Bhabhor
    Neel_Bhabhor , Jan 27, 2021 :
    After recent open beta 1 update of os11 on my OnePlus 7T charging speed is reduced to 1.15 hour. To charge phone to 80% to 100% takes 30 minutes. Also charging time while using phone is also reduced. Earlier it is used to charge very quickly. I hope this charging issue will be solved in the next update.
  10. Aaron2017
    KitKat Jan 27, 2021
    Aaron2017 , Jan 27, 2021 :
    Did you disable optimised charging?
  11. Neitred , via OnePlus 7T Pro McLaren Edition , Jan 27, 2021 :
    Use feedback button.
  12. U1552896198023
    Eclair Jan 27, 2021
  13. G_Sabya_Sachi_CfAS
  14. AmolVats
    Donut Jan 27, 2021
    AmolVats , via OnePlus 7T , Jan 27, 2021 :
    We should have been getting stable oxygen os 11 by now.
    Even samsung has released stable version of Android 11 for their S10 and Note 10 devices both came in 2019 🤷🏻‍♂️
    Looks like OnePlus was waiting for samsung to release stable version of their ONEUI so OnePlus could work on their ONEUI 😂
  15. ghostofcain
    Marshmallow Jan 27, 2021
    ghostofcain , Jan 27, 2021 :
    Then maybe, just maybe, you aren't cut out for beta testing? The threat of total data loss doesn't bother you? You are comfortable using the unbrock tool? You don't rely on your device as your sole means of communication?
    OP7T never supported pocket mode.
    You've reported this using feedback links?
    You've reported the minor bugs using feedback link?
    ssagheer, Donald Nice and McJader like this.
  16. zer0se7en
    Ice Cream Sandwich Jan 27, 2021
    zer0se7en , via OnePlus 7T , Jan 27, 2021 :
    Seriously....... To all of you complaining and riding the bandwagon of installing a BETA OS.......
    Why the hell did you get yourself into something you have no idea of doing?😳
    All the warnings are already on the first post. Still.... Complaints, complaints, complaints....😤
    Bad update
    Lots of bugs
    Battery drains
    Not charging properly
    Apps won't open
    Always lag
    After the update, blah blah blah💢
    Damn!💢
    I am not experiencing ALL of these issues from these complaints. Wonder why? Because I know what I have got myself into. I know every workaround because I learned from understanding the Android OS and how it should be used.
    If you don't know what you are getting yourself into, then don't do it. Then here you go complaining and blaming the devs of the company again. OH... MY... GOD...😱
    What a headache these people are!🙀💢🗯️
  17. JeevaOnePlus
    Froyo Jan 27, 2021
    JeevaOnePlus , Jan 27, 2021 :
    its not an issue, i think they trying to save the longitivity of the battery going forward...
  18. Aaron2017
    KitKat Jan 27, 2021
    Same here,apart from a bug or 2,3.if they report the bugs as much as they complain about it,we should have a stable in no time.
    ssagheer, zer0se7en and ghostofcain like this.
  19. McJader
    Indeed.
    zer0se7en likes this.
