455
OxygenOS 11 Open Beta 1 for the OnePlus 7T and OnePlus 7T Pro
  1. hemu29
    Cupcake Jan 29, 2021
  2. hemu29
    hemu29 , via OnePlus 7T , Jan 29, 2021 :
    Read the post again!
  3. Deactivated User
    Jan 29, 2021
    sadman_ likes this.
  4. hemu29
    That is because of the optimization of charging according to your daily usage, you can disable it by going Settings -> Battery -> Optimised Charging but I suggest you do not disable it, it will help your battery to serve more.
  5. hemu29
    No it will not, yes I can say to proceed with installation of Oxygen OS 11 OB1 some minor bugs already mentioned in the post!
    RAJAVINU likes this.
  6. dsmonteiro
    Community Consultant Staff Member Jan 29, 2021
    dsmonteiro , Jan 29, 2021 :
    No, you were temporarily banned because you reached 15 warning points, after countless requests to follow the rules. In fact, I sent you this message privately, that you didn't reply to.
    For reference:
    Hi Chirag,
    My name is David and I'm part of OnePlus' Community team. It was brought to my attention that you're nearing the warning points limit that leads to a permanent ban. This is something that we hate to see happening. The Community Forums are meant to be a friendly place for everyone, regardless of how happy they are with the brand. Still, we need to make sure that the rules are still followed, so that everyone can have a pleasant experience.
    With that said, you're free to be critical of OnePlus, there is nothing wrong with that. However, we cannot allow for users to be impolite to other users or disrupt the forum experience to others in any way. With that said, I kindly ask you to follow the rules, so that we can avoid a ban situation. We'd like to keep counting on your feedback to improve further in the future.
    Also, please note that creating accounts to circumvent your current temporary ban will result in warning points that will cause your account to be permanently banned.
    Kind regards,
    David
    GaneshKunte, geoxar, McJader and 3 others like this.
  7. RAJAVINU
    RAJAVINU , Jan 29, 2021 :
    will u plz explain , shortly
  8. S1609250143677
    Cupcake Jan 30, 2021
  9. DarP_Joshi
    Eclair Jan 30, 2021
  10. dEb_OP7T
    Eclair Jan 30, 2021
    dEb_OP7T , via OnePlus 7T , Jan 30, 2021 :
    Please try to check after a factory reset, if it is okay with you.
  11. Khushdude
  12. G1594867602845
    Froyo Jan 30, 2021
  13. G1594867602845
    Froyo Jan 30, 2021
  14. Varyan
    Gingerbread Jan 30, 2021
  15. G1594867602845
    Froyo Jan 30, 2021
    G1594867602845 , via OnePlus 7T , Jan 30, 2021 :
    Deadline ? Come soon is a common word need Perticulerlly time and date ?? If you do not jave then stop making fool to clients .. Learn from the other brand .
  16. GDawg1
    Froyo Jan 30, 2021
  17. us4ak
    Froyo Jan 30, 2021
    us4ak , via OnePlus 7T Pro , Jan 30, 2021 :
    Coming from Stable OS10 (India)
    Flashed the ROM twice, wiped data. It runs just fine, no problem. Not as stable as OS10 but pretty stable for a Beta, IMO.
    Found a couple text misalignment issues, reported in feedback section.
    Yes, the experience was so buggy, stutters, lags and screen flickers were present after first flash. It didn't wipe data. After second flash and data wipe, everything is back to normal.
    Battery backup just as good as OS10 stable. No abrupt heating or performance issues encountered so far.
    Diabolique and Mohan Reddy Y V M like this.
