457
OxygenOS 11 Open Beta 1 for the OnePlus 7T and OnePlus 7T Pro
  1. AnkurBajaj
    Cupcake Feb 24, 2021
  2. Donald Nice
    Honeycomb Feb 24, 2021
    ghostofcain likes this.
  3. AnkurBajaj
    Cupcake Feb 25, 2021
    AnkurBajaj , Feb 25, 2021 :
    The phone is stuck on the loading screen, I am seeing One big red dot and two white dots rotating around it for 1 hr... :(
  4. Donald Nice
    Honeycomb Feb 25, 2021
    Donald Nice , Feb 25, 2021 :
    Then something went wrong. You can restart your phone a couple of times and it will restore your old system. What was the preinstalled version of your os and which one are you trying to install?
  5. Juergen_Denifle
    Eclair Feb 25, 2021
    Juergen_Denifle , Feb 25, 2021 :
    Sadly doesn't work when you have installed the actual Oxygen OS Version 10.0.16.HD65BA
    I downloaded the ZIP and moved it to Root Directory. Tried to make a "local upgrade" - it says "the version of the choosen package is lower than your actual System. Downgrades are not allowed!"
    Anyone knows whats wrong?
  6. dsmonteiro
    Community Consultant Staff Member Feb 25, 2021
    dsmonteiro , Feb 25, 2021 :
    Let me share with the software team. You should in theory be able to install a newer version (e.g. OB2) when the zip is available, but I'll ask.
  7. Being7t
    Donut Feb 25, 2021
    Being7t , via OnePlus 7T , Feb 25, 2021 :
    Just download the full update pack of latest Android stable 10 version from one plus updater..go to settings .. software update ..upper right setting option ..local upgrade ..and select the latest downloaded pack and it will be installed buddy.
  8. Juergen_Denifle
    Eclair Feb 25, 2021
    That's exacty what i did ... and it doesn't work - it says "the version of the choosen package is lower than your actual System. Downgrades are not allowed!"
  9. Being7t
    Donut Feb 25, 2021
    I guess ..after beta 2 update it has been restricted to downgrade.. because when I was on beta 1 ..I had it downgraded 3 4 times. And now I am going to try it again. Will check and let you know buddy.
  10. Juergen_Denifle
    Eclair Feb 25, 2021
    Thanks a lot :)
    Being7t likes this.
  11. dsmonteiro
    Which package are you trying to install, Open Beta 1? Can you share the file's name?
  12. Being7t
    Donut Feb 25, 2021
    Hey ...I tried ..your right it's now allowing to downgrade now..guess we have to wait for the next beta or stable version of Os 11😓
  13. D1613588293347
    Froyo Feb 25, 2021
  14. D1613588293347
    Froyo Feb 25, 2021
    D1613588293347 , via OnePlus 7T , Feb 25, 2021 :
    İt's available in 7T also, but only with messages and whatsapp
    Karan_Murthy likes this.
  15. Hrishi12
    Eclair Feb 25, 2021
  16. dsmonteiro
    pedritopl and Hrishi12 like this.
  17. Hrishi12
    Eclair Feb 25, 2021
    Hrishi12 , Feb 25, 2021 :
    Can you maybe add this to the original post to avoid confusion?
  18. Hrishi12
    Eclair Feb 25, 2021
    Shortly as in today or in a couple of weeks?
  19. dsmonteiro
    Closer to the former than to the latter.*
    *pending validation.
    pedritopl likes this.
  20. dr_arjun
    Donut Feb 26, 2021
