451
OxygenOS 11 Open Beta 1 for the OnePlus 7T and OnePlus 7T Pro
  1. R1573586579103
    Cupcake Mar 11, 2021
  2. amangoel
    Cupcake Mar 16, 2021
    amangoel , via OnePlus 7T , Mar 16, 2021 :
    Facing Network issue when Both Sim are enabled.
    When One SIM is disabled, Network runs smoothly.
    But when both enabled, facing stability issue even network switching.
  3. ghostofcain
    Marshmallow Mar 16, 2021
    ghostofcain , Mar 16, 2021 :
    OB1 had been deprecated, try installing OB3 instead.
  4. amangoel
    I am on OB3 RIGHT now. And facing the mentioned issue.
  5. ghostofcain
    Try READING the OB3 thread, and posting there if your having problems. I don't see how your going to resolve/report your issue in a thread for an earlier build.
  6. d4n.7
    Cupcake Mar 21, 2021
    d4n.7 , via OnePlus 7T Pro , Mar 21, 2021 :
    I discovered an interesting error that occurred after ending a phone call. When the conversation is over and the screen is blank, I cannot unlock it with a fingerprint, but I have to wake it up with the button and then the fingerprint reader works properly. This problem did not exist in Beta 2, it started in Beta 3 and is still present in Beta 4.
    I use OP 7T Pro Beta4
  7. ghostofcain
    Marshmallow Mar 21, 2021
    ghostofcain , Mar 21, 2021 :
    Report it using the feedback link, and maybe discuss further in the OB4 thread, rather than here in a thread for a build which doesn't suffer the issue.
  8. _Andrei_Vavrita_
    Donut Mar 23, 2021
    _Andrei_Vavrita_ , via OnePlus 7T , Mar 23, 2021 :
    I m trying to rollback on my 7t from beta 4 but it says that the OS im trying to install (the one downloaded from rollback here) it is an older version of currently OS and can not be installed. Help please?
  9. Riccardo Toro
    Cupcake Mar 23, 2021
  10. ghostofcain
    Marshmallow Mar 23, 2021
    ghostofcain , Mar 23, 2021 :
    Try READING the OP again, the instructions are there and shouldn't be beyond anyone who considers themselves a beta tester.
  11. Frochi
    Cupcake Mar 26, 2021
    Frochi , Mar 26, 2021 :
    The instructions only says...download the stable version Oxygen10 and put in the internal storage then manual update but, appear a message...it is an older version of currently OS and can not be installed.
    Anybody try to rollback?
  12. ghostofcain
    Marshmallow Mar 26, 2021
    ghostofcain , Mar 26, 2021 :
    Really? this is what I read.....Want to go back to Android 10? Download the Rollback package from the links below:
    OnePlus 7T - India
    OnePlus 7T - Europe
    OnePlus 7T - Global
    OnePlus 7T Pro - India
    OnePlus 7T Pro - Europe
    OnePlus 7T Pro - Global
    https://forums.oneplus.com/threads/...or-the-oneplus-7t-and-oneplus-7t-pro.1379873/
    Shailender Sharma likes this.
  13. Frochi
  14. ghostofcain
    Curious, as I understand it using the rollback build has worked for others.
    Which rom did you download from the above links? Your file name doesn't look right to me?
    The builds linked are 13 and yours is a 14?
  15. Frochi
    I Downloaded two version to stable OS
    13 and 14
    The results is the same.
  16. ghostofcain
    Marshmallow Mar 27, 2021
  17. ojivraj
    Cupcake Mar 31, 2021
  18. mihaleek likes this.
  19. Sam197
    Ice Cream Sandwich Apr 13, 2021
    Sam197 , via OnePlus Community App , Apr 13, 2021 :
    This thread is for 7t and 7tpro,look for the right thread match your phone
    ghostofcain likes this.
