457
OxygenOS 11 Open Beta 1 for the OnePlus 7T and OnePlus 7T Pro
  1. Iamchemist
    Eclair Jan 21, 2021
  2. Aaron2017
    Lollipop Jan 21, 2021
    Aaron2017 , via OnePlus 7T Pro , Jan 21, 2021 :
    Maybe a factory reset will help with that,or otherwise you can always roll back to the stable os 10 version.
  3. Imraan69
    Eclair Jan 21, 2021
    Imraan69 , via OnePlus 7T Pro , Jan 21, 2021 :
    Many of you must have already updated to the newly released OOS 11 BETA 1 for the 7/7T series and maybe few of them are quite happy with it while others are worried about the bugs which they're facing.
    I will list things where OnePlus should improve too but here's the list of bugs
    ✓ Fast charging doesn't work anymore , it just shows Warp Charge.
    This is the major issue for me because I was acquainted with it
    ✓Battery capacity reduced i.e., obviously it's a first beta and this bugs is common but this is our duty to let the community/developer to know about it.
    ✓Few files ain't showing up in file manager app like OBB of the game while it's only visible in third party file manager
    Except this I loved OOS each and every time , yup it's so smooth that my eyes can't even adapt quickly.
    Improvements:
    ✓ Please don't use dark grey accent in the Settings and Notification panel , it looks ugly to be honest . Use Pitch Dark accent or give the option to switch between those.
    ✓The space between the keyboard and navigation gesture is too much , reduce it slightly. It will look nicer .
    I will let you know what else you could improve.
    Thank you.
    Chris507 likes this.
  4. Lemillion likes this.
  5. Aaron2017
    Do you mean this beta version?if so,than now if you go to the 7 pro section and download it.
  6. Matt 80
  7. dan_0272 , via OnePlus 7T Pro McLaren Edition , Jan 21, 2021 :
    Side swipe the Music Player Notification either left or right then tap the gear/settings icon which appears & then toggle on 'Hide player when the media session has ended'.
    Shri Prakash Sharma likes this.
  8. ShyleshBare
    Froyo Jan 21, 2021
    ShyleshBare , via OnePlus 7T , Jan 21, 2021 :
    When you try to close that there you can find the settings button..there you can find this option to disable
  9. ShyleshBare
    Froyo Jan 21, 2021
    Copy the file directly into the internal storage and not within any folder.Also make your that your file is with the extention .zip if not rename
  10. Nikhilnikk8
    Donut Jan 21, 2021
  11. Auristic
    Auristic , Jan 21, 2021 :
    As soon as you read Post #1.
  12. Aung Khant Kyaw
    Froyo Jan 21, 2021
    KeeBaud likes this.
  13. camohan
    Moderator Moderator Jan 21, 2021
    camohan , Jan 21, 2021 :
    Hi there, goood compilation unfortunately it will fall to deaf ears unless communicated in right way.
    Please make sure to use official beta thread and read the first post to know how to report bugs and suggest feedback.
    Thread merged.
    SaddyMaddy, aaronpe and Imraan69 like this.
  14. Imraan69
    Eclair Jan 21, 2021
    Thank you for bringing it to the light 😋
