455
OxygenOS 11 Open Beta 1 for the OnePlus 7T and OnePlus 7T Pro
  1. T1592066964789
    Cupcake Jan 21, 2021
  2. Tausif.Shaikh007
    Gingerbread Jan 21, 2021
  3. dan_0272
    dan_0272 , Jan 21, 2021 :
    When it is Ready.
    ghostofcain and sugan07 like this.
  4. ManinBlack99
    ManinBlack99 , via OnePlus 7T , Jan 21, 2021 :
    Hello,
    If I'm already on open beta version of 7T, then will it still wipe the data?
  5. Donald Nice
    Honeycomb Jan 21, 2021
    Donald Nice , Jan 21, 2021 :
    Nobody can give a clear answer to that. For me, coming from ob9 and using the internal updater, nothing was wiped / erased and everything working smooth. Try that, but backup first!
    With the links from first post its often mentioned that data will be wiped.
    ghostofcain and Neitred like this.
  6. dan_0272
    Have u locked & unlocked the device once after the sunset time (or the specified custom time) coz the theme only changes automatically after the screen is locked & unlocked in order to maintain stability.
  7. M1572948040753 , via OnePlus 7T Pro , Jan 21, 2021 :
    Thanka mate... Also i need to install open beta 9 over my 10.0.13 and then i can uodate via ota? Okay i will try....
    Dont want a full reset my phone was cleaned a few weeks ago
  8. ManinBlack99
    No actually I got a update fro mthe settings directly since I was in the beta. Saw just now.
    But thank you!
  9. Aaron2017
    KitKat Jan 21, 2021
    Aaron2017 , via OnePlus 7T Pro , Jan 21, 2021 :
    Same here,went from beta 9 to this one and lost no data.but like they say always back up as there is always a risk of data loss.
  10. Nikhil_Kashid
    Nikhil_Kashid , Jan 21, 2021 :
    I'm on stable build, if I download android 11 beta and install it then will there be any data wipe?
  11. godzinilla
    Eclair Jan 21, 2021
    godzinilla , via OnePlus 7T Pro , Jan 21, 2021 :
    Hello. Is there a way to enable VoLTE and VoWiFi on OP7TPro with current beta of OxygenOS11?
    The PDC application does not shows my phone. Any thoughts about it?
    Both connections were activated on my device before upgrading, now both options are still available under system settings, but does nothing.
  12. Caomhin
    OnePlus 9 Series Expert Community Expert Jan 21, 2021
    Caomhin , via OnePlus 6T , Jan 21, 2021 :
    This might be worth a try.
    This is for all OP phones, however it discuses the 8 Series, but it should apply to any series as the protocols are the same.
    [GUIDE] Enable VoLTE & VoWiFi on all devices NO ROOT.
    https://forum.xda-developers.com/on...nable-volte-vowifi-devices-root-t4105817/amp/
    Log Kit 1.0
    https://www.apkmirror.com/apk/onepl...ase/onepluslogkit-1-0-2-android-apk-download/
  13. realpanik
    Froyo Jan 21, 2021
  14. Tausif.Shaikh007
    Tausif.Shaikh007 , via OnePlus 7T , Jan 21, 2021 :
    I have tried the lock and unlock but it has not worked yet. It's 6:30pm here but dark mode has not kicked in yet.
  15. T1579152346323
  16. C4Prophet
  17. dsmonteiro
    Community Consultant Staff Member Jan 21, 2021
  18. maciejbromley
  19. dan_0272 , via OnePlus 7T Pro McLaren Edition , Jan 21, 2021 :
    Try Auto Dark mode with the custom time range & then lock/unlock the device & if it doesn't change automatically then report this as a bug report through feedback section of the community app.
    Tausif.Shaikh786 likes this.
  20. avengear79
    Eclair Jan 21, 2021
    avengear79 , via OnePlus 7T Pro , Jan 21, 2021 :
    So, I have been rocking this OB1 since yesterday. I got it through OTA.
    I haven't restored my phone, wiped cache or anything, and it runs very stable, I haven't noticed a single bug so far.
    There is a Google play system update bug under security and lock screen in the settings that crashes, but I guess it is not because of this beta. I don't even know what that is, it showed up in my notifications bar the day before the beta came out and it wanted to restart my phone to finish updating. But when I restarted the update came up again and wanted me to restart again. This update crashes after I installed OB1.
    Thank you OnePlus!
