459
OxygenOS 11 Open Beta 1 for the OnePlus 7T and OnePlus 7T Pro
  1. McJader
    The Lab Reviewer - OnePlus 9RT 5G Writers' Club Jan 21, 2021
  2. Boomer112
    Eclair Jan 21, 2021
    dsmonteiro likes this.
  3. dsmonteiro
    Infamous Mastermind Staff Member Jan 21, 2021
    dsmonteiro , Jan 21, 2021 :
    Are you using stable software or a previous open beta build?
    McJader likes this.
  4. Satheesh.R.
    Gingerbread Jan 21, 2021
  5. rmstrasel
    Froyo Jan 21, 2021
  6. McJader
    McJader , Jan 21, 2021 :
    Then you won't recieve it through OTA
    Manual installation only option
    Satheesh.R. likes this.
  7. WAQUAR_ALAM
    Froyo Jan 21, 2021
  8. avengear79
    Eclair Jan 21, 2021
  9. McJader
  10. McJader
  11. dsmonteiro
    Open Beta is only available if you manually install it. If you're using stable builds, you'll receive OxygenOS 11 when its stable build is available.
    WFred, ShreyasPatil_ and Satheesh.R. like this.
  12. Satheesh.R.
  13. ithy83
    Cupcake Jan 21, 2021
  14. rmstrasel
    Froyo Jan 21, 2021
  15. StaR_BoY
    StaR_BoY , via OnePlus 7T , Jan 21, 2021 :
    This new update was really awaited, and I am really quite happy to use the new OxygenOS 11 (beta). I am expecting to get a stable update as soon as possible and I know the devs are working on it. The known issues were faced but i am facing some other issues as well which are not listed,
    1. The macro camera takes only one shot and then the camera app stops working and doesn't even pop a notification for that.
    2. The warp charging is fairly fast as before when the phone is idle, but relatively slower when i am using the device.
    3. There is a sudden flick of brightness when gboard is opened in whatsapp inbox.
    4. A slight imbalance in the brightness slider, at a certain point, while decreasing brightness, it starts decreasing unusual low.
    Apart from all these I am missing the old version of OxygenOS and on the same time I didn't dislike this version, I hope we will get a proper stable update. ☺️
    Mr Olo, rmstrasel and Chiranjit Das like this.
  16. McJader
    Yes, because they hadn't found it yet. It is your job to find bugs and report them through the link I mentioned
    WFred likes this.
