450
OxygenOS 11 Open Beta 1 for the OnePlus 7T and OnePlus 7T Pro
  1. McJader
    Lollipop Jan 21, 2021
    McJader , Jan 21, 2021 :
    Yes, because they hadn't found it yet. It is your job to find bugs and report them through the link I mentioned
    WFred likes this.
  2. Q1577845727237
    Cupcake Jan 21, 2021
    WEBSDCOOL likes this.
  3. McJader
  4. gangshugar
    Froyo Jan 21, 2021
    gangshugar , via OnePlus 7T , Jan 21, 2021 :
    A error i found. I switched to navigation swipes but still navigation buttons are visible. Until i restarted the device this problem was present
  5. Boomer112
    Eclair Jan 21, 2021
    Boomer112 , via OnePlus 7T , Jan 21, 2021 :
    Ok... So... I'm extremely confused. I can't seem to install it... I've downloaded the correct file and everything but i don't know how to actually install it. Do i need Android 11 before i can install? I'm so confused...
  6. gangshugar
    Froyo Jan 21, 2021
  7. BalazsNemeth
    Eclair Jan 21, 2021
    BalazsNemeth , Jan 21, 2021 :
    I've got this bug too, your problem is maybe because of chat bubbles. After I closed my opened chat bubbles via MANAGE button at the bottom, it's normal again.
  8. gangshugar
    Froyo Jan 21, 2021
    1. Ensure that you kept the downloaded file in the root folder of storage
    2. If the file has .zip.jar then remove the .zip from downloaded file it should be always .zip only
    3. Now go the update section and choose local upgrade. It should work now
  9. N1591279949970 , via OnePlus 7T Frosted Silver , Jan 21, 2021 :
    Any way thanks for your words..but I decided to wait for OTA update..bcz, it may come with stabled version.
  10. gangshugar
    Froyo Jan 21, 2021
    Wait for 2 more months, you may receive stable ota
  11. McJader
    Ok steps for installation:
    Go to File Manager>Downloads>Find the file you downloaded>Hard click on it>click on three dots on top right>click on copy>click on internal storage>click on paste
    Then again hard click on the file>click on 3 dots>click on rename>if .jar is present, remove it.>click on ok
    Go to settings>click on system>system updates>click on gear like icon on top right>click on local update>click on the file and install it
  12. emailtosivakumar
    Froyo Jan 21, 2021
  13. krowaan
    krowaan , Jan 21, 2021 :
    So the links are available again, but it doesn't say it won't erase all data. Is it safe?
  14. emailtosivakumar
    Froyo Jan 21, 2021
  15. Dipto79
    Gingerbread Jan 21, 2021
    Dipto79 , via OnePlus 7T , Jan 21, 2021 :
    Solve-- Yes it's a bug.... it's happening if you use bubble feature (proven)
    Now the solve is not to restart your phone.... This solve can save this time although it's not permanent solve
    Search bubble and disable problem gonna solve or if you really wanna use bubble feature apply that again you have to repeat this again again to use bubble feature
    That's bug spotted by me first (i asked in forum but one said to wipe my cache 😂 they think clearing cache can save everything 😂)
    Enjoy
    abidxkamal likes this.
  16. emailtosivakumar
    Froyo Jan 21, 2021
    emailtosivakumar , via OnePlus 7T , Jan 21, 2021 :
    Will I lose data if I reboot??
  17. gangshugar
    Froyo Jan 21, 2021
    I moved from stable to beta .. so it erased data but if you are already a beta, then it won't
    emailtosivakumar likes this.
  18. Kvl_21
    Honeycomb Jan 21, 2021
  19. Aaron2017
    KitKat Jan 21, 2021
