457
OxygenOS 11 Open Beta 1 for the OnePlus 7T and OnePlus 7T Pro
  1. lukaszlol1990
    Cupcake Jan 22, 2021
    lukaszlol1990 , via OnePlus 7T Pro , Jan 22, 2021 :
    First bug what I found it's not working automatically dark mode, needs be switch on button "manually". When want to set up automatically theme working as white .
    Another one it is interface lags .
    Another, in settings menu gap from top screen to first settings line is to big as blank .
  2. lukaszlol1990
    This is Google app arcs. When showing are only for a few seconds then became hidden .
  3. J1588952037247
  4. Aakash317
    Froyo Jan 22, 2021
  5. BineetBiswas
    BineetBiswas , via OnePlus 7T , Jan 22, 2021 :
    So.. I found 1 bug till now... And that is on my OnePlus 7t, Wifi keeps disconnecting by itself. And then unable to auto reconnect.. user have to do it manually..
  6. Ramu Yandra
    Froyo Jan 22, 2021
  7. E1589537349678
  8. Harxh.2002
    mandar.menjoge likes this.
  9. Kunnu_111
    Kunnu_111 , via OnePlus 7T , Jan 22, 2021 :
    Wifi is disconnecting by itself at regular intervals....well I faced the same issue before beta update as well......ANY SOLUTION TO FIX THE SAME....
    said:
    the charging speed is quite low after update .....
  10. krishnansasi
    Gingerbread Jan 22, 2021
    krishnansasi , via OnePlus 7T Pro , Jan 22, 2021 :
    Dislikes/issues so far
    1. Facing a few lags while enabling Work Profile, taking calls, disconnecting etc.
    2. There are some inconsistencies in the interface, especially deep into the settings.
    3. Camera doesn't focus on main camera until I do a touch to focus.
    4. A few app crashes. Had to restart phone a few times.
    Likes
    1. Battery life is actually better than the last few betas for me.
    2. Fresher interface
    3. Messages are now categorized. Could be more refined though.
    4. New call screen looks cool.
    5. Auto brightness is better than on Android 10 versions.
    Jerome Redido likes this.
  11. Ashwatthama183
    WEBSDCOOL likes this.
  12. Lakshgaikwad
    Froyo Jan 22, 2021
  13. KiranBhand
  14. Shankar Sabs
    Shankar Sabs , via OnePlus 7T , Jan 22, 2021 :
    It will not wipe when you upgrade... Backing up is just for safety since this is a beta build...
  15. Kunnu_111
  16. Dhruvsharma9455
    Froyo Jan 22, 2021
    Dhruvsharma9455 , via OnePlus 7T , Jan 22, 2021 :
    cant able to turn off work profile. on clicking it leads to work-life balance settings. disappears on restarting but appears again later. already submitted feedback. anyone else facing this issue?
  17. McJader
    Marshmallow Jan 22, 2021
    McJader , Jan 22, 2021 :
    report the bugs here
    https://forums.oneplus.com/forums/community-feedback/
    ghostofcain likes this.
  18. Jerome Redido
