458
OxygenOS 11 Open Beta 1 for the OnePlus 7T and OnePlus 7T Pro
  1. Jinen
    Eclair Jan 23, 2021
  2. Anshulg09
    Cupcake Jan 23, 2021
    Anshulg09 , Jan 23, 2021 :
    Hi,
    I have copy the package in phone storage but while going to local upgrade, i can't see the package in one plus 7T phone..kindly suggest..
  3. Jinen
    Eclair Jan 23, 2021
  4. dan_0272
    Gingerbread Jan 23, 2021
    dan_0272 , Jan 23, 2021 :
    Remove the .jar extension from the package & keep it only .zip & do make sure that the package is inside the Internal Storage directory & not inside any other folder.
  5. Q1589691021813
    Eclair Jan 23, 2021
    Q1589691021813 , Jan 23, 2021 :
    Dear one pluse team roll out stable update for one pluse 7 series. I hope your the first device to make it so late to get your previous devices updated. You guys are busy in working on new stuffs but hope you don't forget to give new looks for your previous devices too.
    Fix this out soon team, We are waiting for OxygenOS 11 Stable update not for open beta...
  6. Shivam Kapile , via OnePlus 7T Glacier Blue , Jan 23, 2021 :
    To Known More About Oxygen Os Beta Version 1 For Oneplus 7T Is in The Description Below You Can Watch Overall Video For All The Features That you Wanted To known And Trouble Finding Its Amezing And Have Fun.
    Jinen likes this.
  7. geoxar
    Honeycomb Jan 23, 2021
    geoxar , via OnePlus 7T Pro , Jan 23, 2021 :
    Exactly, nobody expects from a beta update to be stable ever!
    My point was that OxygenOS11 latest beta update to OnePlus 8 Pro (that I own) do not have the UI element bugs mentioned to this large thread. That said, I think that they could take the already evolved UI code from the 8 series and base the 7 series update on the 8 series update instead of starting from scratch.
    Of course I know nothing about their software update strategies and possibly I am completely wrong, I am just speculating here based on the user feedback I read 😉
  8. Skabeis
    Skabeis , Jan 23, 2021 :
    Hi,
    provider and wifi disconnects every 10 seconds.... after the wifi connection is stable -mostly 5th try - no more provider diconnects appear.
    Oneplus 7t Beta 1EU
  9. dan_0272
    If u r on Open Beta then Yes u will get successive Open Beta updates via OTA...
    yashu0069 and M1586942051966 like this.
  10. Anshulg09
    I have done the same thing but still not getting this in local upgrade.
  11. H1548603923254
  12. dan_0272
    Are you sure that you put the package with .zip extension into Storage -> Internal Storage? Also if u r still facing problems refer to the pinned post by @dsmonteiro on page-1 containing a step-by-step video on the same.
  13. Anshulg09
    I have put .Zip but now when i try with .zip so it works. Thanks alot for the help..[e]1f601[/e][e]1f60a[/e]
  14. Aleks_S_L
    Aleks_S_L , via OnePlus 7T Pro , Jan 23, 2021 :
    Hello there, I am wondering if we'll be able to change the clock style on the lock screen and notification shelf, other than that the update is going smoothly for me. Great job
    F1594487628271 likes this.
  15. inferno0230
    Froyo Jan 23, 2021
  16. pixelmaker
    Froyo Jan 23, 2021
  17. bgreddy
    Donut Jan 23, 2021
