92
OxygenOS 11 Open Beta 2 for OnePlus 8T
  1. red_cruz25
    Eclair Mar 22, 2021
    red_cruz25 , via OnePlus 8T , Mar 22, 2021 :
    Wrap Charging DOESN'T WORK.
    Fix ACCESSING CAMERA ON LOCKSCREEN.
    On stable builds, Accessing camera on LOCKSCREEN doesn't work. It's just black SCREEN
  2. foxystorm
    Cupcake Mar 22, 2021
  3. Seenu_Krishna
    Gingerbread Mar 22, 2021
    Seenu_Krishna , via OnePlus 8T , Mar 22, 2021 :
    Anybody please help me , I can't go back to stable version. I downloaded latest stable OOS and start flashing by local but its showing like this
    After that I entered in recovery mode but there is no option like install from internal storage.
    Only wipe cache, advanced and exit that's it
    Ashok_Varma likes this.
  4. Attached Files:
    Seenu_Krishna likes this.
  5. Ashok_Varma , via OnePlus 8T Aquamarine Green , Mar 22, 2021 :
    https://oxygenos.oneplus.net/OnePlu...all_2012162253_downgrade_4d2ad477302542e2.zip
  6. Vicky345
    Eclair Mar 22, 2021
  7. Anshu2705
  8. AashishT
    Donut Mar 22, 2021
    AashishT , via OnePlus 8T , Mar 22, 2021 :
    Please fix the charging speed sometimes being slow and also small stutters in the overall usage. and also the battery backup.
    PS : Using OnePlus 8T 12Gb ram
  9. sunny_kaura
    Eclair Mar 22, 2021
    LVPC1970 likes this.
  10. Shinra_Tensei
    Eclair Mar 22, 2021
    Nikhil_Bhilai and Anshu2705 like this.
  11. Anshu2705
  12. tomekv1
    Eclair Mar 22, 2021
    tomekv1 , Mar 22, 2021 :
    I installed both beta (UE) versions and found no problems. Everything works as it should. Also the battery holds well with me.
    AussieAndy likes this.
  13. S1550548660570
  14. Majd992
    Eclair Mar 22, 2021
    Majd992 , via OnePlus 8T , Mar 22, 2021 :
    When are you going to activate 5G services on the phone in the UAE ?, you've been giving false promises to fix the issue since october .This is a major feature that you should have given it a high priority because this is the main reason I have bought this phone for.!
    U1614681433855 likes this.
  15. U1614681433855
    Donut Mar 22, 2021
    U1614681433855 , via OnePlus 8T , Mar 22, 2021 :
    Dear OnePlus team,
    Kindly reply to this post
    Majd992 likes this.
  16. fedrox
    Froyo Mar 22, 2021
    fedrox , Mar 22, 2021 :
    For me too. It's always like this. I don't understand compliances, over and over. This is silly
  17. Caomhin
    OnePlus 9 Series Expert Community Expert Mar 22, 2021
    Caomhin , via OnePlus 6T , Mar 22, 2021 :
    As you are Voluntary BETA Testers. As per the first post at the top of the thread. You can use one or more options below to send Bug reports on the issues you are having back to the OnePlus OOS developers.
    Feedback tool
    You can also contact bughunters@oneplus.com
    Gavindi likes this.
  18. JouJol
    Donut Mar 22, 2021
  19. suman1979
    Froyo Mar 22, 2021
    AussieAndy and Gavindi like this.
  20. Arvindlakra_21
    Froyo Mar 22, 2021
    Arvindlakra_21 , via OnePlus 8T , Mar 22, 2021 :
    So, some how was able to resolve this issue I faced for few weeks. Searched various Widevine L1 threads and found solution for this issue. First you need to go in setting->Application & notification-> find Netflix app. Force stop it and clear storage and cache. Then disable the Netflix app. Restart ur device.After the boot-up has completed go back to Application & notification, find Netflix app and re-enable it. Now check Widevine security level and u will find its back to L1. Hope it works for u.
    dwaipayanray likes this.
