158
OxygenOS 11 Open Beta 3 for the OnePlus 7 and OnePlus 7 Pro
  1. akks
    KitKat Mar 3, 2021
    akks , Mar 3, 2021 :
    It's a known issue. Battery life is okay when AOD is turned off.
    yashu0069 likes this.
  2. ScottyJavea
    Cupcake Mar 3, 2021
    ScottyJavea , Mar 3, 2021 :
    Hi All,
    I ran the AOD after Beta 3 during last night, 2nd-3rd, and it used 30% battery.
    Obviously this had to be addressed for the final version.
    ScottyJavea
    yashu0069 and the_reckoner like this.
  3. akks
    KitKat Mar 3, 2021
  4. PiTRiS87
    Gingerbread Mar 3, 2021
    PiTRiS87 , Mar 3, 2021 :
    Seeing these Betas, I wonder what will be there first - stable Android 11 for OP7 or General Android 12 Beta availability :D
    this is terrible for previous gen phones... OP has really gone to **** :(
    B k, yashu0069 and the_reckoner like this.
  5. dannyjoy
    Cupcake Mar 3, 2021
    dannyjoy , via OnePlus 7 , Mar 3, 2021 :
    Yes! I actually searched a lot for update but dint get it. Please put up a link for OnePlus 7 oxygen os 11 beta 3
  6. Spade07
    Cupcake Mar 3, 2021
    Spade07 , Mar 3, 2021 :
    After updating my 7 pro to android 11 in the open beta OTA branch, I lost the ability to answer phone calls through Google Fi. The issue is resolved when uninstalling the Google Fi app or booting into safe mode, but then I'm unable to use mobile data and other services included. All outgoing calls, messaging, and data work as normal with the Google Fi app installed. It's possible the issue arose from any one of the three beta updates, though I'm unsure which. Downgrading back to the Android 10 Beta 19 has solved the problem for now.
  7. rayprayas03
    Ice Cream Sandwich Mar 3, 2021
    Enigmaxregrem and yashu0069 like this.
  8. akks
    KitKat Mar 3, 2021
    Yes, that's already clarified
  9. Sam160901
    Cupcake Mar 3, 2021
    Sam160901 , via OnePlus 7 Pro , Mar 3, 2021 :
    I don't know if it's a problem only on my phone but my canvas feature haven't been working since the start of the os 11 beta update on oneplus7pro
    I've been trying everything just to make it work but it just changes the lock screen and main screen wallpaper and does Literally nothing to the AOD or ambient display.
    yashu0069 and caillou0201 like this.
  10. Shalin05
    Honeycomb Mar 3, 2021
    Shalin05 , via OnePlus 7 Pro , Mar 3, 2021 :
    Heyy Buddy
    Just wanted to know the review of Beta 3 (7 Pro)
    Any major bugs/issues or is it a ready driver for daily use?
  11. SandeshChinchapur
    Jelly Bean Mar 3, 2021
  12. akks
    KitKat Mar 3, 2021
    for me, no issues at all. Charging time has tad improved as compared to beta2. i had been using even beta 1 as daily driver, since then on beta channel itself. beta 3 is quite stable for me. yet to encounter any major bug. i guess stable should be out soon, if this goes well for sometime.
    PS: I dont use AOD anymore. If its enabled, as mentioned in the OP, battery life will be too low
  13. V_S_Surya_Kiran
    Cupcake Mar 3, 2021
  14. akks
    KitKat Mar 3, 2021
    if you are on beta2, there nothing much groundbreaking, in beta3. just a bit polished, thats all. and probably with AOD in OP7 too, which again you wont use much as its a battery sucker as of now.
  15. SandeshChinchapur
    SandeshChinchapur , Mar 3, 2021 :
    That POLISH is all I want. App opening from notifications is very slow on beta 2, also overall performance is slow. To add to it, I have wifi connection issue. Soo many reasons to wait for an update.
  16. akks
    KitKat Mar 3, 2021
    If you have slow app opening, lag and all, I doubt it won't be fixed, even with beta3, as it's probably not related to the rom.
    Wifi connectivity issues, Yes. As mentioned in OP
    yashu0069 and C1562961418484 like this.
  17. SandeshChinchapur
    Then? Will that be the same even on stable update you mean?
  18. T1541419101648
    Cupcake Mar 3, 2021
  19. rayprayas03
  20. akks
    KitKat Mar 3, 2021
    No, I mean, bug fixes will be definitely there on each beta builds. But major lagging and slowness need not be always rom related. I can't exactly say, as I'm not using the same apps as you use, I'm not using phone the same way as you do. So may be some conflicts do happen in your phone which occur due the contents on your phone. Only the common issues reported ought to be fixed. As you mentioned, wifi connectivity issues are fixed in beta 3 and is definitely a reason for you to wait for beta 3. Also probably AOD shall come in this build. What I meant to say is that, it's not that great big update if you are on beta 2.
    Shalin05, Sreeram_Nath and gdsingh94 like this.
