158
OxygenOS 11 Open Beta 3 for the OnePlus 7 and OnePlus 7 Pro
  1. akks
    KitKat Mar 17, 2021
    akks , Mar 17, 2021 :
    Check your battery stats, some app/process is excessively using the processor in the background.
    Artemus. and yashu0069 like this.
  2. Porkey111
    Eclair Mar 17, 2021
    Porkey111 , via OnePlus 7 Pro , Mar 17, 2021 :
    Has anything been done to fix the ui bug where the lock screen zooms to.being double the size? It's been present in beta 1 and 2 causing the software to be unusable for me.
    yashu0069 and rayprayas03 like this.
  3. tjtan1772
    Froyo Mar 17, 2021
    tjtan1772 , Mar 17, 2021 :
    It's still doing it on Beta 3.
    yashu0069 and Porkey111 like this.
  4. Porkey111
    Eclair Mar 17, 2021
    That's sucks sigh. I guess it's bugs like that keeping the stable release back. I just hope when it finally drops I don't have to deal with bs like that no more. I have no problem waiting but I just hope it's good after all this time.
    yashu0069 likes this.
  5. rayprayas03
    Ice Cream Sandwich Mar 17, 2021
    rayprayas03 , Mar 17, 2021 :
    It's officially confirmed by Oneplus..
    What the hell is happening...
    They have to change Hydrogen OS to Color Os till March 24..
    May be because of this we will get late Update...
    Alex.242, dkishorereddy and yashu0069 like this.
  6. MoHiTsOoD,
    Honeycomb Mar 17, 2021
    MoHiTsOoD, , via OnePlus 7T , Mar 17, 2021 :
    Joke of the year
    rayprayas03 and yashu0069 like this.
  7. dkishorereddy
    Cupcake Mar 17, 2021
    dkishorereddy , via OnePlus 7 Pro , Mar 17, 2021 :
    Hey akks, thanks for your quick reply..
    I had verified before posting my message, no background applications are running.
  8. denson9874
    denson9874 , via OnePlus 7 Pro , Mar 17, 2021 :
    I found out that when the device wakes from sleep, it causes the DPI issue. It does matter the app, AOD or Display Resolution, it just randomly scales to a DPI that requires it to have to reboot.
  9. Sumit393
    Froyo Mar 17, 2021
    guigreg likes this.
  10. danybozga
    danybozga , Mar 17, 2021 :
    hi guys a big question I'm trying to install beta on my onpleus 7 pro I'm doing everything like it should when i go to local update no files there what should i do can anyone help me please
  11. akks
    KitKat Mar 17, 2021
    Edit the name of the downloaded file, from a file manager. Remove the .jar and make it just .zip.
    After renaming check local update, it should be there.
  12. danybozga
  13. akks
    KitKat Mar 17, 2021
    Some random process is definitely eating your ram. If you can't figure it out, do a soft reset, or if still persisting do a hard reset.
  14. akks
    KitKat Mar 17, 2021
  15. danybozga
  16. ShubhS11
    Froyo Mar 17, 2021
    ShubhS11 , via OnePlus 7 , Mar 17, 2021 :
    Its for the better,
    ColorOS is more popular in China, and now they dont need to develop 2 separate flavors of same rom for Global and China.
    Plus, this means they can futher customize OOS to global liking.
  17. danybozga
  18. Linkin1994
    Linkin1994 , Mar 17, 2021 :
    think the split started sooner. the Nord series was not in China either. the development of OOS and Hydrogen may have been completely separate.
    rayprayas03 likes this.
  19. Luarpc
    Luarpc , Mar 17, 2021 :
    Where is the file? The screenshot doesn't show the file, only folders. If the file is inside the download folder, you have to take it from there and put it on root directory.
