120
OxygenOS 11 Open Beta 4 for the OnePlus 7 and OnePlus 7 Pro
  1. Suraj gurav 007
    Ice Cream Sandwich Mar 21, 2021
    rayprayas03 likes this.
  2. rayprayas03
    rayprayas03 , Mar 21, 2021 :
    Disable it bro..
  3. O1578234034326 , via OnePlus 7 Pro , Mar 21, 2021 :
    When will get stable update for oneplus 7 pro? And what is the reason for delay?
    And I am asking how got the stable android 11 update for oneplus Nord before the oneplus 7 pro series although OnePlus is mid range and OnePlus 7 pro is a flagship smartphone I think OnePlus doesn't care their flagship smartphone & no timely update provide.
    DSTear likes this.
  4. rayprayas03
  5. MoHiTsOoD,
    Honeycomb Mar 21, 2021
  6. Gokul7373
    Gokul7373 , via OnePlus 7 Pro , Mar 21, 2021 :
    Please read the previous post clearly......he said hydrogen os will be moved to color os.......so that I said next will be oxygen os
  7. Gokul7373
  8. zyciowstret
    Donut Mar 21, 2021
    zyciowstret , via OnePlus 7 , Mar 21, 2021 :
    The only problem I'm experiencing on OB4 fro OnePlus 7 is the fact that sometimes there are animations stuttering in certain apps despite the fact they are up-to-date and it does happen in the UI itself.
    Akshay_Sindhu and rayprayas03 like this.
  9. rayprayas03
    Ohh !! My bad
  10. rayprayas03
    It may be fix in next beta and stable update..
  11. zyciowstret
    Donut Mar 21, 2021
    I hope so. I think wiping cache did solve the problem, at least for some time.
  12. rayprayas03
    I don't think soo, may be you need to do hard factory reset or else wait for the next update to come..
  13. zyciowstret
    Donut Mar 21, 2021
    Only if I had time for that haha. For now it works just fine
  14. isk_snlar
    Donut Mar 21, 2021
    isk_snlar , via OnePlus 7 , Mar 21, 2021 :
    They Said it's Last of March or Beginning of April.. now march is almost done, so maybe in April
  15. Esondor
    Cupcake Mar 21, 2021
  16. Murti52
    Eclair Mar 21, 2021
    Murti52 , via OnePlus 7 , Mar 21, 2021 :
    Are you using OP7..? Also incoming calls going to speakerphone..? I mean, if someone calls you, it goes directly to speakerphone and not the earpiece..? Strange because i am using OP7 and I don't have that problem.. OB1, 2 and 4.. all are working fine.
  17. AdityaMagdum108
  18. kmaier
    kmaier , via OnePlus 7 , Mar 21, 2021 :
    My screen went black for a while. Couldn't awake it so did a restart and all ok. Wondering if it was a bug with the vision comfort setting. Otherwise pretty smooth so far.
  19. manideepgoka
    Gingerbread Mar 21, 2021
    Kashishakul likes this.
  20. SANDEEP7016
    Eclair Mar 21, 2021
