120
OxygenOS 11 Open Beta 4 for the OnePlus 7 and OnePlus 7 Pro
  1. gdsingh94
    Jelly Bean Mar 21, 2021
    gdsingh94 , Mar 21, 2021 :
    Turned on always on display??
  2. manideepgoka
    Gingerbread Mar 21, 2021
  3. AdeebHyd
    Eclair Mar 21, 2021
    rayprayas03 likes this.
  4. cran12
    Froyo Mar 21, 2021
    cran12 , Mar 21, 2021 :
    7pro 8/256. Yes, when I answer a call it goes directly to speakerphone. The speaker icon is not lit but it is on speakerphone. If I call out it is fine unless I turn the speaker on, then I can't shut it off. This started since A11. I used to use Google phone app and switched back to system app and it doesn't matter, same results.
  5. Murti52
    Eclair Mar 21, 2021
    Murti52 , via OnePlus 7 , Mar 21, 2021 :
    You could downgrade to a10 and see if the problem is there and then upgrade to a11 and check.
  6. cran12
    Froyo Mar 21, 2021
    I figured I'd just live with it untill an update resolves it. For now I just hang up on incoming callers and imediately call them back. Like I said in a prior post, I'm not complaining as I realize this is beta, I'm just letting others know.
    Your downgrade suggestion I might take just for curiosity.
    Murti52 likes this.
  7. M1541636714502 , via OnePlus 7 Pro , Mar 21, 2021 :
    I tried that back on Beta 2 and it still didn't resolve the issue. This issue has been present since Beta 1 of OOS11. Factory reset doesn't fix either, nor does flashing the Full Update instead of the incremental. Switching Phone Apps haven't fixed it either for me. It seems to be baked into OOS11 itself and not modularized.
  8. Shyciii
    Cupcake Mar 21, 2021
    Shyciii , Mar 21, 2021 :
    When I update to beta 4, login to account message appear in top of the setting menu. Anyone confirm it too?
  9. cran12
    Froyo Mar 21, 2021
    Ya I factory reset after Ob2 and switched phone app and the results are the same. I was thinking of rolling back after it was just suggested to see if it was somehow hardware related. Do I understand you correctly that the issue was fixed for you when you rolled back and then came back when you reinstall beta?
  10. rayprayas03
    Ice Cream Sandwich Mar 21, 2021
    rayprayas03 , Mar 21, 2021 :
    Do a hard factory reset, it may resolve after that
  11. Krishnan S
    Eclair Mar 21, 2021
  12. njb7
    Eclair Mar 21, 2021
  13. M1541636714502 , via OnePlus 7 Pro , Mar 21, 2021 :
    The issue has never been present until OOS11 betas were released. Even OOS10 Open Beta 19 and lower did not have this issue.
  14. karna11
    Eclair Mar 21, 2021
    karna11 , Mar 21, 2021 :
    who said there is no official announcement stop misleading
  15. Nagesh_Pattanshetty
    Nagesh_Pattanshetty , via OnePlus 7 , Mar 21, 2021 :
    I can confirm the issue of AOD shifting to the right. I've experienced this as well.
  16. DaRkNeSs9923
    DaRkNeSs9923 , via OnePlus 7 , Mar 21, 2021 :
    OP users*: Complain about batteries discharging too fast after each beta
    also OP users*: Ask OP to add AOS
    also also OP users*: Complain even more because the batteries are discharging very fast after activating AOD
    *Not all OP users.
  17. rushirajpagoti
    Eclair Mar 21, 2021
  18. Narada2XK
    Donut Mar 21, 2021
    Narada2XK , via OnePlus 7 Pro , Mar 21, 2021 :
    It's nice to receive these updates. What I want to know is how difficult is it to upgrade the security patch? We're heading into the month of April and we're still on January 2021.
  19. Narada2XK
    Donut Mar 21, 2021
    Have you ever considered it being your handset or a batch of handsets?
  20. ShivamGumber
