61
OxygenOS 11 Open Beta 4 for the OnePlus 7T and OnePlus 7T Pro
  1. akaloith
    Froyo Mar 30, 2021
    akaloith , Mar 30, 2021 :
    i am on beta 4 on 7t
    doesnt let me upgrade to stable 11 cause it says its older
    i would have to wait for beta5 or new stable?
    any easy way instead of going to stable 10 first?
  2. imamysofficial
    Gingerbread Mar 30, 2021
  3. Aaron2017
    Jelly Bean Mar 30, 2021
    Aaron2017 , Mar 30, 2021 :
    Don't update to beta 5 if it comes first, and wait until the next stable build is released. But back up everything, when you change channels everything will be wiped
  4. Chirag_Gohil
    Honeycomb Mar 30, 2021
    Chirag_Gohil , via OnePlus 7T , Mar 30, 2021 :
    Why play music app is here! Its jot working. It was closed by google still why here? Why not remove?
    gauthampaik likes this.
  5. rajat04099
    rajat04099 , via OnePlus 7T Pro , Mar 30, 2021 :
    Use unbrick tool and flash any of the stable rom. Make sure to backup your data before doing anything. Coz, this involves data loss so
  6. Aaron2017
    I don't know. I do now you can remove it on the 8 pro now, so maybe in future updates it'll be possible on 7t series as well. For now, you can just disable it if you want
  7. Z1611314562403
    Cupcake Mar 30, 2021
    Z1611314562403 , Mar 30, 2021 :
    Hello everyone. If I upgrade from stable 11 to 4 beta, will the battery life improve? Now it is impossible to play games, heating up to 40 C, and the battery lasts for a maximum of 5 hours of screen operation, including 1 hour in the game.
    Dpack likes this.
  8. Dpack
    Eclair Mar 30, 2021
    Dpack , via OnePlus 7T Pro , Mar 30, 2021 :
    I am using 7t pro it s going upto 43 degree while gaming
  9. K1616673712356
  10. Dpack
    Eclair Mar 30, 2021
    While gaming battery just drains so bad.. for light usage it is fine.. i m on beta 4 and lil bit bugs in camera the processing happens a bit late.. so i am looking for beta 5
  11. K1616673712356
    K1616673712356 , via OnePlus 7T , Mar 30, 2021 :
    I had a camera flicker after switching to stable 11, but after resetting to factory settings everything is ok
  12. Dpack
    Eclair Mar 30, 2021
    Heating issues???? While gaming??
    SunielShakya likes this.
  13. K1616673712356
  14. DotNetCore
  15. nswarnendu
    Froyo Mar 31, 2021
    Dpack likes this.
  16. Narayan13
    Froyo Mar 31, 2021
  17. Paper_Cut
    Eclair Mar 31, 2021
    Paper_Cut , via OnePlus 7T , Mar 31, 2021 :
    I am facing issues in camera app. Can not go to wide angle camera mode. Can not go to portrait mode. I have also tried using google camera. It also is not working at google camera. Anyone else is facing it?
  18. Wellington Ferreira
    Gingerbread Mar 31, 2021
  19. F1588470539128
    Donut Apr 1, 2021
    F1588470539128 , via OnePlus 7T , Apr 1, 2021 :
    I want to revert the camera app to the old one because the light processing produce cloudy images when there's a bright light. The resolution of the cameras becomes dull due to this...my OnePlus 7t was defeated by a Huawei y9. Please fix the camera app. As for the file manager there's a bug when moving and copying folders most specially when moving many folders at the same time...it lags then says it's finish but it's not...it just transfer a portion of the folder...it also affects file compression the same way. I cannot decompress directly to a specific folder when doing this...I love the old file manager app...I don't know why did they update this for what????aesthetics?! Just a crap...function is much important than a beautiful interface that does not function. I'm searching for any bugs...they fix the slow charging anyway but I don't know if I can rely on this...the battery drain is a little fast when playing codm...maybe they still need to calibrate the charging system to effect true charging and battery stats...I'm just comparing to os10.
    nswarnendu likes this.
  20. ankitgondalia
    The Lab - OnePlus 6T Reviewer Apr 1, 2021
    ankitgondalia , Apr 1, 2021 :
    Help! I was on stable 11 build and flashed OB4, it took me to recovery. I did a factory reset from there as it wasnt booting and now its stuck on boot animation screen
    Edit: Had to visit center to get it fixed.
