32
OxygenOS 11 Open Beta 9 for the OnePlus 8 and OnePlus 8 Pro
  1. TigerFaiz
    Eclair Apr 29, 2021
    TigerFaiz , via OnePlus 8 , Apr 29, 2021 :
    Facing same problem, Oneplus 8 working like 9k mobile now..Camera worst,Heating, Hang problem ,app closing automatically.. Pathetic oneplus....
    #81
  2. D45uN1X
    Cupcake Apr 30, 2021
    D45uN1X , Apr 30, 2021 :
    Anyone have a copy of this update? I bricked my phone flashing the wrong boot.img while on Beta 9.
    any assistance in acquiring this will be great. I have created a separate post below because this one is for the beta announcement and I am requesting support. I I can get the boot.img or the .bin file I can get my phone out of a boot loop and close my post below.
    https://forums.oneplus.com/threads/bricked-oneplus-8-pro-beta9.1429171/
    #82
  3. D45uN1X
    I thought it was just me.. I was trying to go back to the stable release but skipped a few steps during a Wipe and reset to check if the Beta 9 was just fixable with a wipe since it seemed to fix it I tried to flash my magisk patched boot.img and it boot looped. Then I tried to flash the stock but realized afterwards I flashed the stable release (facepalm)
    #83
  4. cruzAD
    Gingerbread Apr 30, 2021
    cruzAD , via OnePlus 8 Pro , Apr 30, 2021 :
    Yeah, mine heating strongly also, and fastly discharging, and lags, but I'm on stable 11.0.5.5.BA. I checked the beta forum only because I hoped maybe if I switch to beta it would help.
    #84
  5. #85
  6. Tee_Eee_Bee
    Ice Cream Sandwich Apr 30, 2021
    Tee_Eee_Bee , via OnePlus 8 Pro , Apr 30, 2021 :
    I have pasted a link to the msm tool in your other thread.
    #86
    D45uN1X likes this.
  7. cruzAD
    #87
  8. matrooy
    #88
  9. FMukbil97
    Froyo May 1, 2021
    #89
  10. Vanstra
    Gingerbread May 1, 2021
    Vanstra , May 1, 2021 :
    Not how bad, but how good is it. It's a really good daily driver. Really fast. I've no problems with it.
    #90
    FMukbil97 likes this.
  11. FMukbil97
    Froyo May 1, 2021
    FMukbil97 , via OnePlus 8 Pro , May 1, 2021 :
    Thanks!
    Also, as a beta tester how good is the communication between you and the developers? Do providing feedback actually worth it?
    #91
  12. NexusKnight
    Cupcake May 2, 2021
    NexusKnight , via OnePlus 8 Pro , May 2, 2021 :
    Hello guys, I'm new to Android (coming from iPhone 7 and 11), especially 1st time with OnePlus, 8 Pro to be exact. I have 2 main questions:
    1) How do I do a full back up. Unlike iOS user can do full back up over iTunes, where can I do it with OnePlus?
    2) How do I join and download, install Open Beta builds and how to do a fresh install of the stable build, as well as where to make the switch from Open Beta to Stable path
    I hope to hear from you guys because as of right now, I think my 8 Pro is having some hiccups and wanna try the Open Beta to see if it worths keeping this phone or return it for a 9 Pro or iPhone 12 Pro Max
    #92
  13. ANOOP_VS
    Gingerbread May 2, 2021
    ANOOP_VS , via OnePlus 8 , May 2, 2021 :
    there is a big issue i found on Securty wifi connections...
    these domain option need to remove otherwise we cannot connect to wifi network. in my vessel am using more security wifi connection. i put the usename and password and i cannot connect because phone asking the domain. only i face this problem. rest of all phone models dont have this option and they can connect to the network also.
    #93
    X1592300485579 likes this.
  14. Tee_Eee_Bee
    Ice Cream Sandwich May 2, 2021
    Tee_Eee_Bee , via OnePlus 8 Pro , May 2, 2021 :
    This is due to how wi-fi security is handled in android 11:
    "Android 11 will no longer let you connect to some enterprise WiFi networks" https://www-xda--developers-com.cdn.../android-11-break-enterprise-wifi-connection/
    I'm pretty sure there is an option under the 'CA Certificate' setting called "do not validate". If you select that option (if it's there), you should be able to connect.
    I have this problem with my Pixel 4XL on my workplace wi-fi. It won't connect as the option above has been removed, but my 8 Pro can connect as it still has the option.
    #94
  15. Merriabdessalam
    Cupcake May 3, 2021
    Merriabdessalam , May 3, 2021 :
    You still haven't fixed Google Pay issue. It works just fine on my 6t. But not on 8pro. And now there's issue with some apps when you click on a notification nothing happens. App doesn't open through it. Fixxxxxxxxxxx the darn thing.
    #95
  16. ANOOP_VS
    Gingerbread May 3, 2021
    ANOOP_VS , via OnePlus 8 , May 3, 2021 :
    yeahhh ... ❤️❤️❤️. thank you bro its working..
    #96
  17. Tee_Eee_Bee
    Ice Cream Sandwich May 3, 2021
    #97
    ANOOP_VS likes this.
  18. Ayanprmnk93
    Eclair May 3, 2021
    Ayanprmnk93 , via OnePlus 8 Pro , May 3, 2021 :
    shouldn't have switched to android.. stay with iPhone..
    #98
    bpwest80 and Shubh.A like this.
  19. #99
  20. Arif bori
    Donut May 3, 2021
    abhikothari111 and Dellusiondeny like this.
