160
OxygenOS 12 C.40 update for OnePlus 9 and OnePlus 9 Pro
  1. maximus2708
    Gingerbread Jan 17, 2022
  2. TalhaLaving
    Cupcake Jan 17, 2022
    TalhaLaving , Jan 17, 2022 :
    I have a OnePlus 9 Pro, I updated it to Android 12, but I can't seem to be able to download the latest update
    When I click on software update in the settings, nothing happens, even though it's showing that there is an update
    Anyone else having the same problem?
    And how can I resolve it?
    D1641455256071 likes this.
  3. F1600498605854
    A1617346776120 likes this.
  4. Berti1959
    Berti1959 , Jan 17, 2022 :
  5. Aaron2017
    General Support Expert Award 2021 Jan 17, 2022
    Aaron2017 , Jan 17, 2022 :
    You can install this APK
    https://oxygenos.oneplus.net/OPLocalUpdate_For_Android12.apk
    It's the old system updater with local upgrade which you can use to install the update after you have downloaded it from an external source.
    If the APK ends with . zip you'll have to rename it and delete .zip so it ends with APK
    After that click to install and it will be in your app drawer as a separate app
    Bobbie63 likes this.
  6. Dimos89
    Froyo Jan 17, 2022
  7. maximus2708
    maximus2708 , Jan 17, 2022 :
    Oxygen 12 works fine for me and so do my friends and acquaintances.
  8. maximus2708
    This forum does nothing! only whiners are sitting here, how to read posts !!
  9. Gagandeep7717 , via OnePlus 9 Pro Stellar Black , Jan 17, 2022 :
    I am getting notification that ota is available but when i am opening it its showing up to date all so tride clear deta off Google services fremwork but helpfull and allso installed Google ota repair but it is also having so issu
  10. Gagandeep7717 , via OnePlus 9 Pro Stellar Black , Jan 17, 2022 :
  11. Gagandeep7717 , via OnePlus 9 Pro Stellar Black , Jan 17, 2022 :
  12. Dr.Huy
  13. themadtitan8
  14. Louisbaecke510
    Jelly Bean Jan 17, 2022
    hipporama likes this.
  15. AntTaz
  16. Louisbaecke510
  17. Vampire006
    Froyo Jan 17, 2022
  18. ghostofcain
    Marshmallow Jan 17, 2022
    ghostofcain , Jan 17, 2022 :
    That's fine, I don't think anyone expects you to buy a device that doesn't fit their requirements. Not entirely sure how that fits into a discussion of this particular build though.
