283
OxygenOS 12 C.44 update for OnePlus 9 and OnePlus 9 Pro
  1. TerribleDiabetic
    Honeycomb Jan 23, 2022
    TerribleDiabetic , via OnePlus 9 Pro , Jan 23, 2022 :
    Yeah, sounded like that one was a doozie. The whole thing is a big mess, but this version does feel a lot better. Lucky that you can still use ADB to get rid of Google apps, since you can't simply disable them anymore.
    BeardElk likes this.
  2. TheGrayWolf81
    Gingerbread Jan 23, 2022
  3. JAK246
    Cupcake Jan 23, 2022
    JAK246 , via OnePlus 9 , Jan 23, 2022 :
    Still lot of bugs is there.
    OnePlus 9 processor showing 855 insteed of 888
    If i press close all option it won't clear all recent app.
    It lost the original one plus feeling
  4. Z1618026739306
  5. todaman
    Donut Jan 23, 2022
    sergebiro likes this.
  6. aseferian
  7. aseferian
  8. Nafee_Naeer_F
    Nafee_Naeer_F , via OnePlus 9 Pro , Jan 23, 2022 :
    Indeed, this build is far from finished. said:
    I don't understand what OnePlus is trying to prove by releasing unfinished crap.
    Snapdragon releases a new chip every two minutes, and manufacturers are messing things up, as they try to keep up.
    870 is literally the best, optimized Snapdragon based on the 865.
    888 and 8 gen One are both garbage when it comes to sustained performance..
    OnePlus themselves released phones with 870 after OnePlus 9 pro .. realizing the pile of steaming crap Snapdragon landed them on.
    On top of it all, i think the situation is much worse as Oppo owns OnePlus..
    Which means the work force behind polishing the user experience is segregated and stretched thin, producing results that stench of two things:
    "uninspiring"
    "Passionless"
  9. UrvishOza
    Eclair Jan 23, 2022
    logan_27, MBearr1221 and pualai like this.
  10. Q1637502072463
  11. hystericalmonkey , via OnePlus 9 Pro , Jan 23, 2022 :
    Update is rolled out by batches my friend. I got the same model as you and got the update yesterday.
    Q1637502072463 likes this.
  12. Q1637502072463
  13. kramik
    kramik , Jan 23, 2022 :
    LE2120, is your version Chinese?
  14. pualai
    Froyo Jan 23, 2022
    pualai , Jan 23, 2022 :
    OTA.
    kramik likes this.
  15. B1642906267850
    Donut Jan 23, 2022
    B1642906267850 , Jan 23, 2022 :
    I got my update last night. And promptly lost all internet connection. After trying the sim card in another phone (it didnt work) and then putting a different sim in my OnePlus 9 (it worked), the update corrupted my sim card. I have also found that every time I shut off the phone or reboot, auto rotate is shut off. The hidden apps feature (the way of hiding unused apps) is no longer available. So all the apps I had hidden, I can no longer access.
    Still trying things to see what else has changed. But this hasnt gone well for me.
  16. stanleysf1986
    stanleysf1986 , via OnePlus 9 Pro , Jan 23, 2022 :
    I got my update yesterday. After the update, there appears some flickering lines accross my display, not frequently but sometimes. It is occuring always while when the display gets dim before getting off. Does anybody face the same issue?
  17. bjorndgreen
    bjorndgreen , via OnePlus 9 Pro , Jan 23, 2022 :
    Do a clean wipe.
  18. kramik
    Thank
    I have not yet found the link of the full version for LE2113 that I intended to do a reset and then a local installation.
  19. Diganta Deshmukh
    Diganta Deshmukh , via OnePlus 9 Pro , Jan 23, 2022 :
    Hii,
    I am using OnePlus 9 pro. I updated my software to OxygenOS 12 C.44 yesterday. After the update I found an issue I guess it's a bug. My processor is showing Snapdragon 855 Octacore instead of Snapdragon 888 Octacore. I have attached a screenshot for your reference.
    Also, I found another issue. Lockscreen message is not visible in lockscreen even when it's enabled.
    JAK246 likes this.
  20. ZenoDaGod
    JAK246 likes this.
