283
OxygenOS 12 C.44 update for OnePlus 9 and OnePlus 9 Pro
  1. fefo1993
    Donut Jan 23, 2022
    fefo1993 , via OnePlus 9 Pro , Jan 23, 2022 :
    I had AOD enabled only some hours in the day (and not "always enabled"), and i solved selecting "always enabled", then off and on AOD, and at the end i re-enabled scheduled time.
    MirkoStens likes this.
  2. MirkoStens
    Froyo Jan 23, 2022
    MirkoStens , Jan 23, 2022 :
    After the update, the VoLTE icon for T-Mobile Czech Republic is not displayed, although VoLTE is functional, because the data connection works normally during a call, the icon is displayed for the second O2 Czech Republic sim. I reset the connection for data, wifi, BT, but it didn't help.
  3. jyopig
    Cupcake Jan 23, 2022
  4. KahaiPS
    Eclair Jan 23, 2022
  5. pksmith1968
    Gingerbread Jan 23, 2022
  6. Alxfly
    Jelly Bean Jan 23, 2022
  7. MirkoStens
    Froyo Jan 23, 2022
    Also the same bug, like a lot of people here instead of the processor 888, shows 855 ...
  8. nanunext
  9. AjayThapa
  10. Atul_Pareek
    Atul_Pareek , via OnePlus 9 , Jan 23, 2022 :
    Worst update... Having one plus 9 earlier version have some decent option like brightness cool vibration / app hide was very good and calling pop-up very helpful... But this update getting worse.. please fix this
    D1621226592647 likes this.
  11. nslbiker
    Donut Jan 23, 2022
  12. gfilipp
    gfilipp , via OnePlus 9 , Jan 23, 2022 :
    Put your sim in sim2 hole and you will have again 5G
  13. lyricalsaint316
  14. Q1642379389440
    Q1642379389440 , via OnePlus 9 Pro , Jan 23, 2022 :
    This is absolutely piece of crap ... Snapdragon 855? Phone not compatible with your carrier services ?lagg when scrolling? And many more how is this possible..Never Settle? Whell OnePlus already settled can't handle software for one device not to mention all of them
  15. F1626602399253
    F1626602399253 , Jan 23, 2022 :
    I did the update via Oxygen Updater earlier this day. A couple of things are frustrating.
    First of all, ambient display isn't working. When I receive a notification, only the fingerprint button is lightning up. I don't see the notification itself.
    Secondly, I can't turn off Google Feed. That's very disappointing, because it's very irritating.
    Thirdly, you can finally set that you don't want to see a dot on the icon of the app you received a notification from, but a number of the number of messages. Only you can't see these numbers. When you receive a notification, you see nothing on the icon.
    Are more people having these issues?
  16. nishad.ck007
    Froyo Jan 23, 2022
    nishad.ck007 , via OnePlus 9 Pro , Jan 23, 2022 :
    Check settings!! , Many options changed to default
  17. U1642944542648
    U1642944542648 , via OnePlus 9 Pro , Jan 23, 2022 :
    Can some one help.After the upgrade my work profile is not working. Intelligent hub is connected but apps like Outlook or onedrive don't launch. Nor do I have the option to have a password for the work profile. It worked perfectly well on Android 11.
