249
OxygenOS 12 for the OnePlus 9 and OnePlus 9 Pro
  1. aico60
    Eclair Dec 8, 2021
  2. PuCiNhOOO
    Backstage Star Award 2021 Dec 8, 2021
    PuCiNhOOO , via OnePlus 9 Pro , Dec 8, 2021 :
    You need to check them for each app, and each interaction
  3. aico60
    Eclair Dec 8, 2021
    aico60 , via OnePlus 9 Pro , Dec 8, 2021 :
    Well... thats not good. Anyways, thank you.
    Do you happen to know the fix for the camera? I cant click on any of the marked buttons. said:
  4. WoXeD9
    Eclair Dec 8, 2021
    WoXeD9 , Dec 8, 2021 :
    I had network problem with android 12. I think this needs to be resolved. sms works fine. I can receive outside calls. but I can't search. come on guys. THIS IS A MOBILE PHONE.
    ronyjohn01 likes this.
  5. Mashk
    Froyo Dec 8, 2021
    G1618235821807 likes this.
  6. Swejuggalo
    OnePlus 9 Series Expert Community Expert Dec 8, 2021
    Stickied Post
    Swejuggalo , Dec 8, 2021 :
    Oxygen OS 12 to 11 rollback guide - via Local OTA update.
    Finally, Oxygen OS 12 has arrived. If you, for some reason, need to roll back to 11 this is how you do it.
    It would be great if you also could report in this thread the reason why you are rolling back.
    You can find the needed files here:
    If the Local Update app does not find the downgrade file YRJs instructions below would help.
  7. Kallolray
    Donut Dec 8, 2021
  8. WoXeD9
    Eclair Dec 8, 2021
    yes i am roll back this method and perfectly fine evrythink. So, when will the new version be released?
    ronnymes and the_o2 like this.
  9. G_Barak_D
    Gingerbread Dec 8, 2021
    G_Barak_D , Dec 8, 2021 :
    How do I get rid of this lock screen?? I have no password or anything else set.
  10. Bobbie63
    Nougat Dec 8, 2021
    Bobbie63 , Dec 8, 2021 :
    Well, this thread is now 65 pages, seems people aren’t too happy right now.:rolleyes:
    E1638942159251 and ambush like this.
  11. nakah
    nakah , Dec 8, 2021 :
    Yes I did :)
  12. Rajneeshpal
    Cupcake Dec 8, 2021
    Rajneeshpal , via OnePlus 9 Pro , Dec 8, 2021 :
    This is showing .how to download
  13. Johnathan Wick and Kallolray like this.
  14. Muzahid
    Muzahid , via OnePlus 9 Pro , Dec 8, 2021 :
    Absolutely Disgusting Update. Essential Features Removed in favor of ColorOS. Unnecessary Bulky interface. Glitches Bugs so on.... Should have dropped this device earlier when they announced developer team merge. fk this hoppo team.
  15. [email protected]
    Cupcake Dec 8, 2021
  16. nakah
    I understand your situation, but I do always factory reset, when I do change android versions. I use the time it takes to install apps. Otherwise i will use lot of time to do findings for eact issue there will be.
    Chris1223 likes this.
  17. Swejuggalo
  18. Davidoff65
    Froyo Dec 8, 2021
    Davidoff65 , Dec 8, 2021 :
    I have to ask why are people downloading this update. After reading on here there are issues with Android 12. If u do your research Android 12 is buggy . So its not just One Plus that has a buggy OS
  19. Techbizz
  20. Chris1223
    Ice Cream Sandwich Dec 8, 2021
    Chris1223 , via OnePlus 9 Pro , Dec 8, 2021 :
    This has been around since every version of Android and in this case it actually tells you right there on the screen "swipe up to unlock"
