309
OxygenOS 12 Open Beta 1 for the OnePlus 9 and OnePlus 9 Pro
  1. sickchild
    Gingerbread Oct 27, 2021
    LinusOppoTips likes this.
  2. H1546226145230
    Cupcake Oct 27, 2021
  3. emilianotonello , via OnePlus 9 Pro , Oct 27, 2021 :
    Wanted to suggest respectful users of this forum to use the report feature on the crybaby's posts that do not comply with the forum's rules, to keep it healthier for everyone. It works, posts correctly reported do get erased.
  4. TwoFalcons
    Froyo Oct 27, 2021
  5. Gary_Davies
    Eclair Oct 27, 2021
    Gary_Davies , Oct 27, 2021 :
    I find it quite amusing, this thread.....I would assume people would read this before using the Beta software?.
    Then come on here moaning that it has all the bugs that are mentioned - "In this thread".
    I was expecting this Beta to be awful but it's not that bad.
    Most things work fine, except notifications etc, I can't find a way to disable the Google feed when swiping left, but again not the end of the world
  6. Gary_Davies
    Eclair Oct 27, 2021
    Gary_Davies , via OnePlus 9 , Oct 27, 2021 :
    What's that got to with Beta software?
  7. kãräñ_90564
    Ice Cream Sandwich Oct 27, 2021
    kãräñ_90564 , Oct 27, 2021 :
    if you wish to sell or recycle your old phone in India, then once try it on cashify.
  8. Jardani
    KitKat Oct 27, 2021
    Jardani , Oct 27, 2021 :
    You created 22 pinned threads to bury issue/complaint/problem threads beyond reach 😂😂😂
  9. ageduardo2213
    ageduardo2213 , via OnePlus 9 Pro , Oct 27, 2021 :
    Good afternoon, I've been reviewing the beta version for a couple of days and I noticed that the fluidity of the phone is very good, the extra functions, give the appearance of a cell phone that feels very good, however, I have also presented display problems in the status bar as well as the navigation bar, it is worth mentioning that I have not had reboots or anything like that.the dark mode fails because when using it and wanting to perform an action on the icon of an application, a text balloon appears only in white, the options do not appear
    I am excited and waiting for the stable version to come out, however these problems are taking me to a point where I must return to the stable version of android, because my cell phone is part of My job
    Being able to go back to the stable version of was to be easy or should I do something more complicated, does anyone know?
  10. sickchild
    Gingerbread Oct 28, 2021
    sickchild , via OnePlus 9 Pro , Oct 28, 2021 :
    Hey. About rollback to A11 stable its not hard if you followed the instructions on OP. Because your device is a part of your daily job, backup is a important step. Rollback will erase all your data.
  11. Techbizz
  12. Techbizz
  13. GhostRice23
    Cupcake Oct 28, 2021
    GhostRice23 , Oct 28, 2021 :
    Would find it cool if there is an OxygenOS based design from the merger of the two operating systems, i.e. that you can switch between 2 designs in the settings.
    emilianotonello likes this.
  14. rajaryank
    rajaryank , via OnePlus 9 , Oct 28, 2021 :
    Going by the betas, coloros has pulled it off with elegance.. oos 12 is a pale shadow of whta oos used to be... Not bad per se but not oos class either... Unless beta 2 wows me, i would rather prefer coloros
    Shinjuurou likes this.
  15. Barbuckles
    Donut Oct 28, 2021
    Barbuckles , via OnePlus 9 Pro , Oct 28, 2021 :
    Yeah, the Beta seems to be almost a straight Android 12. I see very little custom stuff added like in Color. I'm hoping they put more effort into desktop mode. Like what Samsung did. I'd like to get rid of my laptop.
  16. evgenybu
  17. evgenybu
    evgenybu , via OnePlus 9 , Oct 28, 2021 :
    Don't agree. The first step says "download and install .apk" - failed. Can't install this app and can't move forward. Help needed
  18. sickchild
    Mine works fine. Install .apk from the link provided from OP.
    1. Download .apk from link given. - open with browser much easier.
    2. Rename downloaded .apk > remove .zip extension. - with file manager.
    3. Install.
    Tested from A12 OB1 rollback to A11 stable and upgrade to OB1 back. Works.
    Then reflash OB1 and reset factory for testing. Works too.
  19. evgenybu
    Thanks, I followed the instructions. This is what I got:
