310
OxygenOS 12 Open Beta 1 for the OnePlus 9 and OnePlus 9 Pro
  1. S1599112582517
    Honeycomb Nov 14, 2021
  2. AmarMo
    Froyo Nov 14, 2021
  3. asish022
    Gingerbread Nov 15, 2021
    S1599112582517 likes this.
  4. ksunil1042
    Cupcake Nov 15, 2021
  5. Cheetosdust
    Moderator, Content Coordinator Moderator Nov 15, 2021
    Cheetosdust , Nov 15, 2021 :
    You can find the official thread for the Open Beta 2 here. ;)
    keithnyc likes this.
  6. S1599112582517
    Honeycomb Nov 15, 2021
    S1599112582517 , via OnePlus Nord , Nov 15, 2021 :
    I just hope OnePlus adds the ability to delete Theme Store like OnePlus Recording, Clone App ,etc. U r a moderator, right❓ Please inform my request to OnePlus officials. It's a humble request 🙏 I'm begging you.
  7. Cheetosdust
    Hello,
    I am indeed a Moderator, but the best way to make that suggestion is to write it yourself.
    If you are visiting the forums via a browser, head here and select the option "Submit Suggestion".
    If you are visiting them via the Community App, just press the "+" button in the bottom right corner and the option "Feedback".
    Hope this helps. ;)
  8. S1599112582517
    I have written them my suggestion but no luck. Maybe u suggest them thee ability to delete Theme Store. Please 🙏🙏🙏🙏🙏🙏🙏🙏🙏
    Cheetosdust likes this.
  9. Simeaoluz
    Simeaoluz , via OnePlus 9 , Nov 15, 2021 :
    Hello everyone. My OnePlus 9 is originally the Chinese version (LE2110). It already came with OOS for me. When I updated to the OB1 the option to enable 5G disappeared. Also, the model number changed to LE2115. Does anyone have a suggestion of what happened? If I roll back to OOS 11, will my model turn back to 2110? There is a chance of bricking? Anyone here made it already? Thanks for the support. Writing from Brazil.
  10. TwoFalcons
    Froyo Nov 15, 2021
  11. Shm3than
    Froyo Nov 16, 2021
    Shm3than , via OnePlus 9 T-Mobile , Nov 16, 2021 :
    What do I rename it to? .apk?
  12. YRJ
    The Lab - OnePlus 7T Reviewer; Community Hero 2020 Community Expert Nov 16, 2021
    YRJ , Nov 16, 2021 :
    Just remove the .jar and save it. You don't have to add anything
    Shm3than likes this.
  13. Shm3than
    Froyo Nov 16, 2021
    It's saying I can't open the file and when I got to update my system there's no option for local update. I'm installing the (except IN) package and moving it from downloads to internal storage then removing .jar
  14. AmarMo
    Froyo Nov 16, 2021
    AmarMo , via OnePlus 9 Pro , Nov 16, 2021 :
    If you want to install ystem update apk delete jar and install it. If you want to update system just .jar rename to .zip
  15. Simeaoluz
    Cupcake Nov 17, 2021
    Simeaoluz , via OnePlus 9 , Nov 17, 2021 :
    Anyone? Please.
  16. Maciek02_PL
    Cupcake Nov 18, 2021
    AmarMo likes this.
  17. Shm3than
    Froyo Nov 19, 2021
    Shm3than , via OnePlus 9 T-Mobile , Nov 19, 2021 :
    It's still not working but I'll just worry about it later thank for your help
    AmarMo likes this.
  18. Maciek02_PL
    Cupcake Nov 19, 2021
