310
OxygenOS 12 Open Beta 1 for the OnePlus 9 and OnePlus 9 Pro
  1. X1619809967164
    Cupcake Nov 22, 2021
    X1619809967164 , via OnePlus 9 Pro , Nov 22, 2021 :
    After the last update a week or two back, I have experienced my phone crashing. On every occation I was navigating with Google Maps on phone or Android Auto. The last time I checked the map before I started driving so I didn't have the app open, but running in the background with no set destination.
    I came to think that the areas where the phone crashed while driving, I was driving into a 5G network sone.
    I have now deactivated "smart 5G" to see if that helps.
    X1637334734976 likes this.
  2. Marius_kd
    Marius_kd , via OnePlus 9 Pro , Nov 22, 2021 :
    Does someone know how to adjust the zoom. For example, the symbols in Snapchat are very large for me and rather small in WhatsApp. Thanks to android 12, all symbols and fonts are of different sizes and not just a little.
    And the fingerprint sensor doesn't work on the always on screen, and the always on screen turn off after some minutes.
  3. X1619809967164
    Cupcake Nov 23, 2021
    X1619809967164 , via OnePlus 9 Pro , Nov 23, 2021 :
    Turning off "Smart 5G" didn't solve it. Still crashed often in 5G sones.
  4. T1558116690363
    T1558116690363 , Nov 23, 2021 :
    Updated.
    Problem number 1 - screenshots are not saved: (is there a solution? I could not find a solution on the forum
    Problem number 2 - parallel Viber does not work! How to fix it, someone decided?
  5. S1599112582517
    Honeycomb Nov 23, 2021
  6. G_Rupesh_Gupta_EcCS
    Cupcake Nov 24, 2021
  7. X1619809967164
  8. Taeyang78
    Froyo Nov 25, 2021
    Taeyang78 , Nov 25, 2021 :
    I have the latest stable version installed (11.2.10.10) I have downloaded OB1 to install it and when it clicks to install it tells me: The version of the package you have selected is lower than the current version of the system. To avoid startup errors, installation of older versions is not allowed) So I can't install the beta version
    F1637836008098 and MrtOtc like this.
  9. MrtOtc
    Donut Nov 25, 2021
    MrtOtc , Nov 25, 2021 :
    I faced the same problem and the download apk is not installed...
    F1637836008098 likes this.
  10. F1637836008098
    Cupcake Nov 25, 2021
    F1637836008098 , Nov 25, 2021 :
    I am experiencing the same issue. I have the newest stable OS version (11.2.10.10) on my device (OnePlus 9), but when initiating the local update I have the same error as Taeyang. I tried with the NA/EU package. (LE2115_11_C_OTA_1230_all_df2125_10100001.zip).
    Any help and updates on this would be greatly appreciated, thank you!
  11. Aaron2017
    Lollipop Nov 25, 2021
    Aaron2017 , Nov 25, 2021 :
    That's because the beta build you're trying to install is a lower version than the stable version you have right now. You would have to wait untill there's a new beta version to install that via local upgrade. That or use the rollback file from the first open beta thread and downgrade to 11.2.9.9 and then install the beta, but this process would require a data wipe so maybe it's better to wait for a new beta, that's up to you to decide.
  12. MrtOtc
    Donut Nov 26, 2021
    MrtOtc , Nov 26, 2021 :
    GG .)
  13. G_Rupesh_Gupta_EcCS
    Cupcake Nov 26, 2021
  14. X1637334734976
    X1637334734976 , Nov 26, 2021 :
    I had the same. It was the 5g that did it. It has not crashed since I turned it off
  15. BillyNectar
    BillyNectar , Nov 26, 2021 :
    Hello, after upgrading to Android 12 beta on my OnePlus 9 PRO the camera and phone app are stuck in the hidden apps section. I can't seem to find a way to get them out of there because they aren't listed under privacy > Hide apps > Hidden. Does anyone have a solution?
  16. dmdukes
    Donut Nov 27, 2021
    dmdukes , Nov 27, 2021 :
    May not work with Android Auto. One of my vehicles lost ability to be controlled by head unit. Rolling back to 11 and doing a Custom Rom for now.
  17. nelsonator1982
    Cupcake Nov 27, 2021
    nelsonator1982 , Nov 27, 2021 :
    hello all.....after updating to build 1 from stable android 11 i lost all pick up of signal from my sim card.....I flashed back to android 11 and all seems to be working fine...I tried the flash twice without sucess...im on a USA model oneplus 9 on visible service....anyone with any idea why I lost signal/service? just to be clear after the upgrade to 12 both the times I neither got cell or data service after until flashing back....Thanks in advance
  18. adnan.makarevic
    adnan.makarevic , Nov 27, 2021 :
    hey guys, can't install the beta 1 package, it's always telling me, that the update was failed at 24%.. it's an brand new oneplus 9 pro, europe, just unlocked the bootloader.. currently no sim, nothing.. i've tried to wipe the device, the same problem.. i'm now installing the latest normal os update, and will try again, but i didn't know that there is an requirement for an os version before you can upgrade.. anyone with the same issue or maybe an idea/solution? many many thanks and best!
  19. adnan.makarevic
    ok guys, it seems that's going to work now, still on installing, but i'm over 50%.. so the solution was to upgrade to the latest os version on android 11.. :)
  20. Vibhanshu_28
    Cupcake Nov 28, 2021
