310
OxygenOS 12 Open Beta 1 for the OnePlus 9 and OnePlus 9 Pro
  1. Ajay33
    Gingerbread Oct 7, 2021
    Ajay33 , via OnePlus 9 Winter Mist , Oct 7, 2021 :
    That's what im confused with.. Is samsung using the same material you as in pixel or trimmed down version of material you.
  2. ginim12
    Cupcake Oct 7, 2021
  3. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Community Expert Oct 7, 2021
    Liehjan , Oct 7, 2021 :
    It's material you, but it only works with Samsung apps for example... It doesn't work with any Google made app.
    Ajay33 likes this.
  4. Aaron2017
    Lollipop Oct 7, 2021
    Aaron2017 , Oct 7, 2021 :
    No, only for the 9 and 9 pro, as your in their thread. Maybe end of this or beginning of next year but there's no ETA
  5. hades162
    Cupcake Oct 7, 2021
    hades162 , Oct 7, 2021 :
    I've just experienced the phone now fail to wireless charge at all with the beta. It was working and then just stopped halfway through the night and won't charge with it at all now.
    Edit: Phone restart has fixed it, but never had that previously with android 11
    tomandco likes this.
  6. Dimarko
    Cupcake Oct 7, 2021
    Dimarko , Oct 7, 2021 :
    if you uninstall the Games application, you can no longer install it! What to do and which version to install? flashing beta 1 does not fix the problem.
  7. MUJI420
    Donut Oct 7, 2021
    MUJI420 , Oct 7, 2021 :
    Someone finally raised this question, I think this is a mistake, OnePlus should fix it, I like the circular folder
    angandas95 and Carlosvcsd like this.
  8. fidus62
    Jelly Bean Oct 7, 2021
    fidus62 , Oct 7, 2021 :
    in OS11 you could make a wipe cache in recovery. Does that no longer exist in OS 12?
  9. Liehjan
    Correct, it's not available in this beta.
    fidus62 likes this.
  10. Vaibhav_Lacman
  11. B_Wrath
    Junior Moderator Junior Moderator Oct 7, 2021
    B_Wrath , Oct 7, 2021 :
    You cannot. It was clearly mentioned to make a backup.
    WakeAwake, the_o2 and Liehjan like this.
  12. B_Wrath
    26 September 2019.
    the_o2, Aaron2017, McJader and 2 others like this.
  13. Last edited: Oct 7, 2021
    NikoForzaBrixen and Liehjan like this.
  14. B_Wrath
    It's not just installing an apk. Read the process again.
    the_o2 and NikoForzaBrixen like this.
  15. Liehjan
    It does yes, just like it was mentioned in the instructions... Without a backup your data is lost forever.
