263
OxygenOS 12 Open Beta 1 for the OnePlus 9 and OnePlus 9 Pro
  1. Chris1223
    Honeycomb Oct 13, 2021
    Chris1223 , via OnePlus 9 Pro , Oct 13, 2021 :
    The file downloads with this name (the full name Will differ based off of the region and model. Mine is a OnePlus 9 Pro NA model) - OnePlus9ProOxygen_22.O.11_OTA_0110_all_2107082120_downgrade_2e0c2b9ecc3c4102.zip.jar
    The actual name needed by the restore APK is OnePlus9ProOxygen_22.O.11_OTA_0110_all_2107082120_downgrade_2e0c2b9ecc3c4102.zip
  2. F_Vaddepally_Mahender_Wd , via OnePlus 9 Pro , Oct 13, 2021 :
  3. Tompi-One
    Froyo Oct 13, 2021
    Tompi-One , Oct 13, 2021 :
    I can't install a system application copied from OxygenOS11 on OOS12 OB1!It would be important to me as it can be used to set up an LTE band.Is there a solution for the installation?
    Screenshot_2021-10-13-14-23-48-83_3d73e98b1ad3bd2575f7a56513d89a0c.jpg 245086115_234044238753529_5058130454283529819_n.jpg
  4. Artemus
    Community Hero 2020 Oct 13, 2021
    Artemus , Oct 13, 2021 :
    What are you trying to do with com.example.tmo? o_O
    ronnyhawks320 likes this.
  5. Tompi-One
    Froyo Oct 13, 2021
    OxygenOS 10-11 system application!
    TMO = T-Mobile
    Good for this:
    Until Oxygen OS11, I set the LTE frequency myself to see which one my phone uses!
  6. Artemus
    My guess is, it's not compatible with the beta?
  7. Chris1223
    Clone phone not letting me restore from local backup (doesn't even see it as an option) and Brave browser looks to not like Android 12 (crashed right away).
  8. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 13, 2021
    Dresa91 likes this.
  9. Tompi-One
    Froyo Oct 13, 2021
    Then there is no way to install I think.
    I hope if you see the stable OxygenOS 12 you will have the T-Mobile system app included.
  10. Sam_khan_786
    Cupcake Oct 13, 2021
  11. King bash
  12. ronnyhawks320
    Ice Cream Sandwich Oct 13, 2021
    ronnyhawks320 , via OnePlus 9 Pro Pine Green , Oct 13, 2021 :
    That is not going to happen. OnePlus is not going to include any T-Mobile apps unless an update is pushed for the T-Mobile version specifically. Global variant and other countries variants will not have any carrier system apps installed in any builds. you might want to look into a TMobile branded device 👍🏻
  13. Tompi-One
    Froyo Oct 13, 2021
    Tompi-One , via OnePlus 9 Pro , Oct 13, 2021 :
    This "TMO" application for OnePlus 6-7-8-9 series is available in all EU and Global OxygenOS systems! In the 9 series, OxygenOS can also be found in 11 as I have always used it!
    M1541636714502 likes this.
  14. ronnyhawks320
    I didn't know T-Mbile offered the 6 🤔
  15. Chris1223
    I don't know if this is a bug or a color OS settings change. I don't see notification icons in the status bar (I'm thinking a bug sense the setting is set to icons).
    RAPC_Abhyudaya likes this.
  16. prfraczek
    prfraczek , Oct 13, 2021 :
    I don't see either:)
  17. Rogerini
    Gingerbread Oct 13, 2021
    Rogerini , Oct 13, 2021 :
    Seem here,only the whatsapp icon, the only bug i seen in this build!!
  18. Chris1223
  19. kalpesh.patil , via OnePlus 7T Glacier Blue , Oct 13, 2021 :
    betaa aisa hai.. pele hum bhi gaye the pele tum bhi jaonge😂
  20. Luis62
    Froyo Oct 13, 2021
    Luis62 , via OnePlus 9 Pro , Oct 13, 2021 :
    After returning to Android 11 ... my opinion is that they are not ashamed to release such an unstable beta, even more so that Beta is a DP3 ... it fails almost all the basics things, networks, camera and many basic applications.
    Google does not release Betas in these disastrous conditions ... we are going from bad to worse
