309
OxygenOS 12 Open Beta 1 for the OnePlus 9 and OnePlus 9 Pro
  1. Caomhin
    OnePlus 9 Series Expert Community Expert Oct 15, 2021
    Caomhin , via OnePlus 9 Pro , Oct 15, 2021 :
    Make sure you have already downloaded the Android 11 Rollback installation file, and removed the .jar extension so it ends in .zip, place the file in your main storage away from any folders.
    Once you have downloaded the APK to allow the installation,
    https://oxygenos.oneplus.net/OPLocalUpdate_For_Android12.apk
    Install it then click on open you should see this screen.
    Click Open, then click on the gear wheel top right and it will detect the Android 11 Rollback file choose it and it will wipe your phone and allow the downgrade to take place.
    Artemus and Dresa91 like this.
  2. Caomhin
    This year its OOS 12 with ColorOS Codebase and some integrations. Next year it will be OnePlus 2.0 which will be OOS 13 even more integrated with ColorOS
    Read more here.
    Explore more on OxygenOS 12
    https://forums.oneplus.com/threads/explore-more-on-oxygenos-12.1500773/
    And here, OnePlus 2.0
    https://forums.oneplus.com/threads/oneplus-2-0-the-next-step-of-our-journey.1499131/
    LinusOppoTips, Artemus and Dresa91 like this.
  3. Cheetosdust
    Moderator, Content Coordinator Moderator Oct 15, 2021
  4. docnok63
    Jelly Bean Oct 15, 2021
    docnok63 , Oct 15, 2021 :
    By the way, the System Update runs through Google and is now at the top of About Phone
    Screenshot_2021-10-15-15-02-18-53_fc704e6b13c4fb26bf5e411f75da84f2.jpg Screenshot_2021-10-15-15-17-41-94_f7aa348215f5d566f9e4ca860f474209.jpg
  5. jdulcey
    Donut Oct 15, 2021
    jdulcey , via OnePlus 9 , Oct 15, 2021 :
    Thanks. I can't install the APK.
    Caomhin likes this.
  6. Caomhin
    When the apk downloads, does the filename end with .zip or .jar, if so, edit the filename and remove that so it ends .apk.
    Tokolozi, jdulcey and Cheetosdust like this.
  7. jdulcey
    Donut Oct 15, 2021
    I renamed it to end in .zip, then I extracted it. Then I cannot install it. By the way, thanks for taking the time to help me out.
  8. Caomhin
    This is the apk file to use as the installer for the Full .zip OOS 11 downgrade file.
    No, the APK file should end in .apk 👍
    Image as downloaded
    Once you remove .zip from the end, the icon will change as per the pic below.
  9. jdulcey
    Donut Oct 15, 2021
    Perfect. What should I do next. I have the rollout package as a .zip.jar. What should I do?
    Caomhin likes this.
  10. jdulcey
    Donut Oct 15, 2021
    Now it is working. Thanks.
    Caomhin likes this.
  11. Caomhin
    Remove the .jar from the full OOS install file sinit ends .zip and ensure the file is then place in the main Root Storage of the phone. Make sure you have Backed up any data you want to save as this will Wipe the phone.
    Then use the APK file as per the steps given in my original reply to you to start the installation back to OOS 11. Follow the onscreen prompts.
    vikasgahlot4u and Chris1223 like this.
  12. Caomhin
  13. vikasgahlot4u
    Donut Oct 16, 2021
    vikasgahlot4u , via OnePlus 9 Pro , Oct 16, 2021 :
    Thanks for mentioning.zip
    It was missing in file name.
    Thanx a ton!
    Caomhin likes this.
  14. vikasgahlot4u
    Donut Oct 16, 2021
    Caomhin likes this.
  15. Justin25
    Eclair Oct 16, 2021
  16. brmbjn
    Gingerbread Oct 16, 2021
    Kenas96 and Justin25 like this.
  17. Kenas96
    Froyo Oct 16, 2021
    Kenas96 , Oct 16, 2021 :
    Exactly, did they fix the most important ones, i.e. the connections?!?!
  18. E1516527207169
    Cupcake Oct 16, 2021
  19. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Community Expert Oct 16, 2021
    C1569916285393 and AaqibAhmad like this.
  20. Liehjan
    Liehjan , Oct 16, 2021 :
    Have you updated to latest version on play store? What's not working in the Google dialer?
