317
OxygenOS 12 Open Beta 1 for the OnePlus 9 and OnePlus 9 Pro
  1. G1632589175580
    Froyo Oct 19, 2021
  2. B_Wrath
    Junior Moderator Junior Moderator Oct 19, 2021
    B_Wrath , Oct 19, 2021 :
    When it is ready ™.
    Auristic, Domi05, Jeff Alamo and 2 others like this.
  3. webnizam
    Gingerbread Oct 19, 2021
    webnizam , via OnePlus 9 Pro , Oct 19, 2021 :
    That's interesting. But in my case I've been using Android Auto with My Honda Accord without any issues until I updated to Android 12. I don't know why but I can see that the Bluetooth disconnects from the car right before Android Auto restart.
    I'll do a soft reset and will try. Anyway thanks for the info.
    sickchild and quini like this.
  4. KRISHNAVM
    Eclair Oct 19, 2021
    Dev05445 and mclarenf1lm like this.
  5. G_Jon_Jacobsen_hVxd
    Donut Oct 19, 2021
    deezid, Auristic, sickchild and 4 others like this.
  6. brmbjn
    Gingerbread Oct 20, 2021
  7. Doggystar
    KondiSiema, deezid, Auristic and 2 others like this.
  8. sickchild
    deezid and Domi05 like this.
  9. MirceaForce
    Honeycomb Oct 20, 2021
  10. B1623002667276
    deezid, sickchild and Domi05 like this.
  11. Sammekl
    Sammekl , Oct 20, 2021 :
    Yes both. On my Mac it doesn't connect and recognise the device. No issues with other devices
  12. Shinjuurou
    Shinjuurou , Oct 20, 2021 :
    Hey guys. I've never used a open beta before, but I really want to test the android 12 beta. So here is my question for experienced user: can I install this without problems in my OnePlus 9 Pro Eu version with codename LE2123? I'm a little bit unsecure since the filename says LE2125...
    LinusOppoTips likes this.
  13. LinusOppoTips
    Donut Oct 20, 2021
    LinusOppoTips , via OnePlus 9 Pro , Oct 20, 2021 :
    It should work fine with any version that isn't India, my flashed LE2120 works fine so you should be alright too, even though it got rebranded to LE2125. Can't test 5G as my plan doesn't have it.
    Shinjuurou likes this.
  14. JulGie1996
    JulGie1996 , via OnePlus 9 Pro , Oct 20, 2021 :
    If beta 2 roll out, do it come as normal software update in the settings or do I have to install the apk?
    Is a second beta planned? I really hope this isn't the final version. I hope to see more of the pixel 6 extras. Really like the look of it.
  15. RazvanScutea
    RazvanScutea , via OnePlus 9 Pro , Oct 20, 2021 :
    It comes like a normal update. OTA.
    Nortti72 likes this.
  16. Shinjuurou
    Shinjuurou , via OnePlus 9 Pro , Oct 20, 2021 :
    Yeah I already expected the rebrand. But this shouldn't be a big issue. I also don't have 5G, so will also be no Problem. Thank you very much for this information.
  17. JulGie1996
    First you have to do is install nova launcher for normal working experience
  18. Shinjuurou
    Why is that? Is the oxygen launcher not working correctly?
  19. JulGie1996
    It's laggy. Sometimes you have to force the restart. It doesn't look like android 12. It's looking like android 11 with oppo os.
    I would say do not do the update. Maybe beta 2. There is no single feature from original android 12 (like pixel)
  20. Shinjuurou
    I already decided to wait for beta 2. But still thanks for the advice.
    I'm also saw a video with the new features, so I know there won't be many new features, which a Little but sad. But that's not the reason I want to try the beta. I want to know if the problems I had with Android 11 are fixed.
