319
OxygenOS 12 Open Beta 1 for the OnePlus 9 and OnePlus 9 Pro
  1. Velavan Blue31
    Cupcake Oct 20, 2021
  2. E1581210208031
    Eclair Oct 20, 2021
  3. sickchild
    Gingerbread Oct 20, 2021
  4. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 20, 2021
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Oct 20, 2021 :
    Heard about more people that had problems with connectivity.
    Some cases has been in the past been that the speeds exceed the rated speeds of the cable and cause random drop outs of hard to detect the device.
    But in your case it it could be something else of course.
    I usually connect with orginal cable via an USB 2.0 port or via a USB 3.1 GEN1 cable if no USB 2.0 port is available.
    I usually connect to my home computer running Manjaro. Works fine.
  5. Swejuggalo
  6. RazvanScutea
  7. Swejuggalo
  8. Swejuggalo
    Swejuggalo , via OnePlus 9 Pro Morning Mist , Oct 20, 2021 :
    There are plenty of other options. Nova, Lawnchair, Niagara... And it won't matter. Super customizable or slim and light... All up to you. All can work with both Discover and Shelf now too.
    matthew.dattilo likes this.
  9. Swejuggalo
    Guess you could try to reset the launcher and Shelf components on the phone by wiping app data on both.
  10. RazvanScutea
    RazvanScutea , via OnePlus 9 Pro , Oct 20, 2021 :
    It's about OS integration. No smooth animations with 3rd party launcher. And op launcher was the best out there.
  11. matthew.dattilo
    Froyo Oct 20, 2021
    matthew.dattilo , Oct 20, 2021 :
    I'm using Nova with Beta 1 and it's been a great experience.
    LinusOppoTips and sickchild like this.
  12. Swejuggalo
    Notice any worse animations? Use Niagara on one device and stock on the other. Can't really notice anything worse with Niagara.
  13. F1618685418533
  14. Swejuggalo
    What do you mean with unstable display?
    There are never any exact ETA. However Open Beta is scheduled for monthly updates. It does not mean there always will be exactly 1 month though.
  15. Thews
    Thews , via OnePlus 9 , Oct 20, 2021 :
    While it is true that the update doesn't bring much in terms or huge graphics improvements or strong material U pixel-like elements, it's not true that it doesn't look like Android 12.
    Buttons, dialogs and assets are the one from stock Android 12 redesigned with material U style, settings menu is basically the same as stock Android 12, the launcher is the same from Android 12 with a few things added, the new scrolling bounce animation is taken from Android 12.
    Again, at first sight it's hard to figure any major difference, but using it all around makes you feel some Android 12 vibes.
    As for the usability, I agree on waiting for the next beta hoping to have something more stable.
    Shinjuurou likes this.
  16. X1567496646380
    X1567496646380 , Oct 20, 2021 :
    We need a way to fix the 2 not working options in Face Unlock! Who can help to fix these?
    1) go to home screen after unlocking
    2) screen brightness in low light conditions
