319
OxygenOS 12 Open Beta 1 for the OnePlus 9 and OnePlus 9 Pro
  1. rajaryank
    Gingerbread Oct 24, 2021
    rajaryank , via OnePlus 9 , Oct 24, 2021 :
    Too many nagging issues now! Seriously planning to rollback.. heard coloros12 open beta 2 is a lot more smoother.. OP should rather bring that ... Disappointing
  2. rajaryank
    I think coloros 12 would've been better if the plan was to merge! Certainly OOS12 not off to a good start
    LinusOppoTips, BMG1900 and Techbizz like this.
  3. rajaryank
    Where did you download tht?
    bwright16 likes this.
  4. Techbizz
  5. Bigmike1985
    Froyo Oct 24, 2021
    Bigmike1985 , Oct 24, 2021 :
    From this link on techibee YouTube channel
    rajaryank likes this.
  6. Bigmike1985
    Froyo Oct 24, 2021
    ColorOS Open beta 2 is definitely smoother
    X1567496646380 likes this.
  7. rajaryank
  8. X1567496646380
    X1567496646380 , Oct 24, 2021 :
    We need ob2 NOW! It's impossible that notification icons still don't appear in status bar. And it's impossible that options like Brighter screen in dark room doesn't work in Face unlock.
    Yag1z likes this.
  9. racasnar
    Cupcake Oct 24, 2021
    ronnyhawks320 likes this.
  10. Bigmike1985
    Froyo Oct 24, 2021
    Yes just download The ColorOS open beta 2 zip, then use the rollback APK to flash the zip like a local update
  11. rajaryank
    Last q.. did you go from oos OB 1 to this or did you roll a k to oos11 and this?
  12. gfilipp
    gfilipp , Oct 24, 2021 :
    I download and install and me the new oxygen os beta 1, and I have some issues, in the status appear only the messenger icon when you have a new message, other application not show icon in status bar.. :( and also I can't connect now in 5G network in Cosmote Greece, only show 4g+
  13. Anth0o0
    Eclair Oct 24, 2021
    Anth0o0 , via OnePlus 9 , Oct 24, 2021 :
    I have never tried a beta, I love my OnePlus but I am scared of potential bugs and others bugs very critical like remove data ..
    I hesitate to try this beta because I have a real frequentbut problem with OnePlus launcher but it's app in OnePlus so maybe it can change nothing ...
  14. Bigmike1985
    Froyo Oct 24, 2021
    Yes I flashed it right over oos OB1
  15. brmbjn
    Honeycomb Oct 24, 2021
    brmbjn , via OnePlus 9 Pro , Oct 24, 2021 :
    Wipe datat
  16. AyrtonJVRS
  17. ronnyhawks320
    Ice Cream Sandwich Oct 25, 2021
    LinusOppoTips likes this.
  18. Bigmike1985
    Froyo Oct 25, 2021
    Bigmike1985 , Oct 25, 2021 :
    You don't need to wipe data, and flashing this over oos OB 1 doesn't wipe data either
  19. X1631465620257 , via OnePlus 9 Pro , Oct 25, 2021 :
    Enjoy the update for the most part. Wanted to bring up a coupe bugs in case someone knew of a workaround.
    1. Random apps were stored into my hidden apps section.
    This normally wouldn't be a problem but I cannot unhide any of those apps now.
    Long hold does not work, and there is not the hamburger icon (3 dots) on the top right.
    2. No alarm clock pop (when going off)
    To my knowledge there is no notification or pop up alert that your alarm is going off.
    You have to unlock the phone, and go to your alarm (which is now in my hidden apps) and toggle on and off the alarm to stop it.
    Thanks again!
    ~John
  20. ronnyhawks320
    ronnyhawks320 , via OnePlus 9 Pro Pine Green , Oct 25, 2021 :
    Not sure what your issue is but when my alarm goes off I either slide left to snooze or slide right to dismiss. You might want to do a clean install after wiping all data? 🤷🏻‍♂️
    sickchild and X1631465620257 like this.
