319
OxygenOS 12 Open Beta 1 for the OnePlus 9 and OnePlus 9 Pro
  1. rajaryank
    Gingerbread Oct 25, 2021
    rajaryank , via OnePlus 9 , Oct 25, 2021 :
    Indeed sir... Coloros12 beta 2 is just smooth! A lot smoother than OB1 of oos 12
    LinusOppoTips likes this.
  2. AhMeD_nOr
    Cupcake Oct 25, 2021
    AhMeD_nOr , Oct 25, 2021 :
    can i install it locally like i installed oxygen 12 beta ?
  3. X1631465620257 , via OnePlus 9 Pro , Oct 25, 2021 :
    Yeah it worked fine prior to the update I suppose I could redo and delete my data
    ronnyhawks320 likes this.
  4. ronnyhawks320
    Ice Cream Sandwich Oct 25, 2021
  5. Bigmike1985
    Froyo Oct 25, 2021
    Bigmike1985 , Oct 25, 2021 :
    Yes just do a regular local update like you're used to doing
  6. X1631465620257 , via OnePlus 9 Pro , Oct 25, 2021 :
    Maybe it's because the update pushed my alarm clock into the hidden apps , if only I could move or unhide them lol
  7. brmbjn
    Honeycomb Oct 25, 2021
    brmbjn , Oct 25, 2021 :
    LINK PLEASE FOR ONEPLUS 9 PRO
  8. ramchalamkr
    Donut Oct 25, 2021
    ramchalamkr , via OnePlus 9 Pro , Oct 25, 2021 :
    Was there any china specific apps present in coloros 12 ? Also did you have any trouble with Google play store when you installed it over oos12 ob1 ? Thanks
  9. P1616873722955
    P1616873722955 , Oct 25, 2021 :
    I'm on the beta 2 with OP 9Pro and have a major bug where no images, either captured by camera or screenshots can be saved.
    The "photos" app is disabled and cannot be enabled (the button to enable it isn't clickable).
    Anyone else experiencing this or having a workaround?
  10. D1626431351680
    Donut Oct 25, 2021
  11. M1626194814187
  12. rajaryank
  13. rajaryank
    Yes there are many China specific applications! This rom Good for exploring but not regular use of you're a global user
  14. B_Wrath
    Junior Moderator Junior Moderator Oct 25, 2021
    B_Wrath , Oct 25, 2021 :
    What are you trying to achieve?
    Such demands. It is a beta. It is bound to have bugs.
    If you can't handle it, go back to stable build.
    Demanding things here is useless.
  15. Kenas96
    Froyo Oct 25, 2021
    Kenas96 , Oct 25, 2021 :
    I remember on Oneplus 8 pro beta ... There were no such serious problems. Here is embarrassment! And you don't see revolution or evolution.
  16. B1623002667276
    B1623002667276 , via OnePlus 9 , Oct 25, 2021 :
    Thats if the rom is close to google now its the other way😜
  17. rajaryank
    Thats true.. demanding is always useless! Can be logged as feedback and if that's not implemented, we always can ho back to stable build or custom rom or some other device
  18. zzzharpreet
    Eclair Oct 25, 2021
    purestock007 and N1634471408842 like this.
  19. B_Wrath
    sickchild likes this.
  20. Sujay Kamath
    Froyo Oct 25, 2021
    Sujay Kamath , via OnePlus 9 , Oct 25, 2021 :
    You can unhide the apps just go to settings then privacy there you will see hide apps input your password now you can unhide or hide apps
