147
OxygenOS 12 Open Beta 2 for the OnePlus 9 and OnePlus 9 Pro (Include questionnaire)
  1. JensLiu
    Cupcake Nov 15, 2021
  2. Salilsarkar
    Froyo Nov 15, 2021
    Aaron2017 likes this.
  3. Salilsarkar
    Froyo Nov 15, 2021
  4. Kenas96
    Froyo Nov 15, 2021
    Kenas96 , Nov 15, 2021 :
    in beta 1 it was so that after changing the dpi it changed to the default after a while. Is that also the case here? stay on 11 or install beta 2?
  5. Nyantech01
    Eclair Nov 15, 2021
  6. Aaron2017
    General Support Expert Award 2021 Nov 15, 2021
    Aaron2017 , Nov 15, 2021 :
    Tbh, i would prefer that over the way Oppo has implemented that. From what i saw that only adjusts the accent color in the notification panel and in the settings menu to the wallpaper colors, whereas Google's way adjusts the icons as well. If recently installed lawnchair 3 launcher, which is based on Android 12, and that supports Google's way of theming too and i really like it, although the theming doesn't change the icons from third party apps yet, same as with Google. But, OnePlus might just do it the way Oppo does, given the merge thing.
    Salilsarkar likes this.
  7. Salilsarkar
    Froyo Nov 15, 2021
    Salilsarkar , via OnePlus 9 Pro , Nov 15, 2021 :
    Yeah actually in my opinion that would be a better implementation than samsung not oopo
    SriNord and Aaron2017 like this.
  8. Just__Arpan
    Honeycomb Nov 15, 2021
    Just__Arpan , via OnePlus 9 Pro , Nov 15, 2021 :
    But more polished
    That's what was important since ob1 had a lot of glitches.
    Ob3 can be new features and stuff
  9. Nyantech01
    Eclair Nov 15, 2021
    Nyantech01 , via OnePlus 9 Pro , Nov 15, 2021 :
    Yes agree alot means alot of them .. for me on my OnePlus 9pro
    Just__Arpan likes this.
  10. TathaA1
    Froyo Nov 15, 2021
  11. brmbjn
    brmbjn , Nov 15, 2021 :
    can you explain the bugs you are experiencing?
    because I don't get any significant bugs.
    quite reasonable for beta software.
    I just can't activate LIVE CAPTION.
    other than that it runs fine.
  12. mt19
    mt19 , via OnePlus 9 , Nov 15, 2021 :
    A but of feedback on OnePlus 9:
    - 5G works just fine with VoLTE enabled under Swisscom network
    - I can't show the notification drawer even if the setting in notification & status bar -> pull down on lock screen is enabled
    - home control in the power menu are strange: when I try to add new tiles, I can't see anything in my home. I need to open the home app and update a couple of times. After a bit, the tiles show up again, but as long as I do not close the settings and I reopen them.
    - the home control tiles in the power menu are not centered
    - when I double click a notification in the lock screen, I should be asked for the finger print first, and then for the password. At the moment the keyboard shows up, then I need to close it to put my finger print
  13. AhMeD_nOr
    Donut Nov 15, 2021
    AhMeD_nOr , Nov 15, 2021 :
    new beta stop my sim card
    old android 11 no notification and no 5g
    now i am using color os beta 3 and this is last oneplus phone i buy
    i never buy your phones again
    4 month struggling with this ******* phone
  14. seraph758
    Donut Nov 15, 2021
    seraph758 , Nov 15, 2021 :
    My mobile phone has been upgraded to beta2. It loses power quickly and generates a lot of heat.
  15. tersant85
    Eclair Nov 15, 2021
    tersant85 , Nov 15, 2021 :
    I cannot actually say what the issue is, however I have tried many solutions (like clearing data for photos app, gallery app, camera etc. cleared cached) I was only able to get it to work normally after factory reset. After that, the phone works close to perfect
  16. cyvr1
    Froyo Nov 15, 2021
    cyvr1 , Nov 15, 2021 :
    I don't know if this has been posted already. If so, I appologize for posting it again.
    I just found a great new feature (?) in OOS12 which, if I remember correctly, has been often asked for in OOS11.
    Now you can disable taking screenshots with Volume down + Power Switch. You find it in the Settings/System settings/Convenience tools/Screenshot. There is also a new(?) gesture for taking a partial or scrolling screenshot.
    pds324 and Aaron2017 like this.
  17. Salilsarkar
    Froyo Nov 15, 2021
  18. SriNord
    Ice Cream Sandwich Nov 15, 2021
    SriNord , via OnePlus Nord , Nov 15, 2021 :
    Sorry, rest of these world uses Color OS premium with Chinese apps removed.
  19. SriNord
  20. SriNord
    It's never gonna happen again.
