147
OxygenOS 12 Open Beta 2 for the OnePlus 9 and OnePlus 9 Pro (Include questionnaire)
  1. patts75
    Eclair Nov 26, 2021
    patts75 , via OnePlus 9 Pro , Nov 26, 2021 :
    No reset going from OOS11 -> Beta1 -> Beta2. No bugs so far. Everything works. But i seems like that's not the case for the majority in this forum. I guess i was lucky.
  2. ralph12
    Eclair Nov 26, 2021
    ralph12 , Nov 26, 2021 :
    so there is no other way to install beta on the new 11.2.10.10 ? until they release full beta ?
  3. docnok63
    Jelly Bean Nov 26, 2021
    docnok63 , Nov 26, 2021 :
    I have no idea what was wrong with your setup, but COS doesn't do that for any of my apps. Everything works normally for me.
    No, you'd have to downgrade to 11.2.9.9 in order to install OB1 which will wipe your phone. Stable is coming soon™. Just wait for that.
    deezid likes this.
  4. ralph12
    Eclair Nov 26, 2021
    😢 so I made huge mistake . hopefully they release full rom of next beta 3 if not I will have to sacrifice and downgrade with full wipe
    thanks for answer
    deezid, jigarmak and Caomhin like this.
  5. Techbizz
    Gingerbread Nov 26, 2021
    Techbizz , via OnePlus 9 Pro , Nov 26, 2021 :
    Open beta 2 is quite satisfactory with few below mentioned changes required.
    1. Round icons theme don't match with system theme. System theme always in square.
    2. OnePlus sans font is different. Not as per the actual one in oxygen os
    3. Battery percentage not shown when notification panel is pulled down..
    4. App icon personalisation not possible. I cannot change icon of each app as before in oxygen os 11. This is basic oxygen os feature
    5. Fingerprint sensor doesn't work many times.
    6. Camera is very bad. It is not able to focus in night. Portrait mode doesn't work. Please fix this on urgent basis. The pics are not as clear as per hasselblad promise.
    deezid and jigarmak like this.
  6. DaRegulator
    Cupcake Nov 26, 2021
    DaRegulator , via OnePlus 9 Pro , Nov 26, 2021 :
    In addition to the icon support issues, there are a significant number of apps that are not fully supported by Android 12. I use the Microsoft launcher exclusively, so no feedback on the Oxygen UI.
    Notifications for many apps, all of which are beta ate also not coming through in real time :
    Outlook - completely dead for notifications
    Facebook - get them in real time, won't refresh in app
    Snapchat
    Instagram
    Signal
    Line
    Gmail is completely dead for notifications
    Icon for 5G is broken. Stuck on VoLTE.
    Battery percentage does not appear in pull down.
    9Pro.
  7. Caomhin
    9 Series Expert, Participator of the Year Community Expert Nov 26, 2021
    Caomhin , via OnePlus 9 Pro , Nov 26, 2021 :
    Unless you downgrade to 11.2.9.9 or below beforehand, but it will cause a phone wipe, so you would need to backup everything on the phone first.
    Liehjan and Aaron2017 like this.
  8. ralph12
    Eclair Nov 26, 2021
    i know 😭 . i wait until they release next beta , hopefully it will be full rom if not then i downgrade because I can't wait stable android 12 , it will take ages.
    thanks anyway for your help
    Caomhin likes this.
  9. L1615049966349
    L1615049966349 , Nov 26, 2021 :
    Hello.
    I'm on beta 2 and I just noticed that I don't have the wireless reverse charging option anymore.
    I have a EU version and I had that option on Android 11.
    The wireless charging is working.
    Thanks.
    [email protected] likes this.
  10. Caomhin
    As there is no specific EU rom. Did you install the India or Global beta. India version may not have the necessary API, Global might but as its Beta it may not be enabled or may be an issue.
    Aaron2017 likes this.
  11. L1615049966349
    I took the global. Not indian version. My normal wireless charging is working well.
    I understood that indian phones doesn't have it.
  12. Caomhin
    Then you may need to report it as a Bug.
  13. Techbizz
    Gingerbread Nov 27, 2021
    deezid and themadtitan8 like this.
  14. themadtitan8
    Eclair Nov 27, 2021
    themadtitan8 , via OnePlus 9 Pro , Nov 27, 2021 :
    I faced this once, I had to force restart the device.
    deezid likes this.
  15. Techbizz
    Techbizz , via OnePlus 9 Pro , Nov 27, 2021 :
    How did you force restart? I was not able to do it with completely pressing power button for long time.
  16. luca6140
    Cupcake Nov 27, 2021
    luca6140 , Nov 27, 2021 :
    I also had a lot of screen problem, I noticed it was when I received a notification, I turned off bubble notifications
  17. themadtitan8
    Eclair Nov 27, 2021
    deezid likes this.
  18. M.F.Mushtaq
  19. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Community Expert Nov 27, 2021
    Liehjan , Nov 27, 2021 :
    I'm on OB2 and the reverse charging is there.
    I'm on the global beta2 and the reverse charging quick tile is there, and charging is working. I just tried it :)
    Caomhin likes this.
  20. Liehjan
    You should not unzip the package.
    Caomhin likes this.
