353
OxygenOS 2.1.0 OTA roll-out starting now!
  1. Rohit Prakash
    Cupcake Oct 1, 2015
    Rohit Prakash , Oct 1, 2015 :
    #spencer1620: Dear Brother, we understand that there are many post on 'Facebook Not Working' so does by only reading and listening to the issue, if the same gets resolved; if yes we all will do that. Also in none of the threads or post, manufacturer or Admin #Helen has given any solution so that we may follow that and not write back. We are using these forums to let the manufacturer to know that a lot of people are facing issue. We have paid a good amount of money on these phones and feedback should be given to them. Thanks :)
  2. spencer1620
    Ice Cream Sandwich Oct 1, 2015
    spencer1620 , Oct 1, 2015 :
    This thread is 137 pages long 75% of that is people bleating on about Facebook not working I'm pretty sure op know about it by now.
    So all you are achieving is stopping people using this thread to highlight other problems by saturation it with "Facebook Doesn't Work".
    SnowPower likes this.
  3. jmudrick
    Honeycomb Oct 1, 2015
    jmudrick , Oct 1, 2015 :
    And the solution, to use version 42 , has been posted 737 times. It takes less time to search than to post.
    otto2, SnowPower and spencer1620 like this.
  4. vikramaditya64
    Donut Oct 1, 2015
  5. spencer1620
    Nothing wrong here
  6. nh_opu
    Froyo Oct 1, 2015
    nh_opu , Oct 1, 2015 :
    Agree woth u
  7. Namelessghoul
    Namelessghoul , Oct 1, 2015 :
    I hope we don't need an invite foe this :eek:
  8. nemu123
    Cupcake Oct 1, 2015
  9. Sterling27
    Cupcake Oct 1, 2015
    Sterling27 , Oct 1, 2015 :
    I haven't even updated yet and I've got the same party going on mine.
  10. jetli78
    Eclair Oct 1, 2015
    jetli78 , Oct 1, 2015 :
    Bonjour à tous, depuis la nouvelle mise à jour d'oxygène 2.1.0.sur mon OnePlus 2, facebook s'ouvre plus.. J'ai desinstaller, installer facebook toujours rien, que dois-je faire ? Aidez moi s'il vous plaît merci.
  11. yudtui
    Cupcake Oct 1, 2015
    kables likes this.
  12. yudtui
    Cupcake Oct 1, 2015
  13. GMCF
    Cupcake Oct 1, 2015
    GMCF , Oct 1, 2015 :
    Hi Helen
    I got my OP2 just few days back. My set has also detected OS Update notification. But after download, I cant installed it due to installation failure. It happened several times. Any solution??
  14. Gunjan Ft Shady
    Gingerbread Oct 1, 2015
  15. SadButTrue
    SadButTrue , Oct 1, 2015 :
    v48 isn't an android 5.0.+ version (it is an android 4.0.3+ version) so this should not be the 1st choice version
    take a look here: https://www.apkmirror.com/?s=facebook&post_type=apps_post
    and i didn't think tis is a OxOS 2.1 problem this is a facebook app problem -> take a look at the playstore comment's of the last days...
  16. dhanninacs
    dhanninacs , Oct 1, 2015 :
    Have you rooted it? It not normally would not install by istself if it's rooted.
    If you haven't rooted just dowload the OTA from the forums and manually update the zip from stock recovery.
  17. vinpilu
    vinpilu , Oct 1, 2015 :
    What happens when you going to settings and reconfigure the colors? Is it still "disco lights" or fixed?
  18. namanshah1986
    Cupcake Oct 1, 2015
  19. yasinsiddiqui
    Eclair Oct 1, 2015
    yasinsiddiqui , Oct 1, 2015 :
    Don't be surprised if 100% of the people who're complaining about the Facebook App not working have NOT done a Wipe/Factory Reset after installing the 2.1.0 OTA update!
    As an Android developer, I'm pretty sure that the Facebook app not working because Android Lollipop can't load 32-bit & 64-bit libraries concurrently.
    I've got 3 OP2s with 2.1.0 on which Facebook is working perfectly fine.
    spencer1620 likes this.
  20. mukesh tiwary
    Eclair Oct 1, 2015
