353
OxygenOS 2.1.0 OTA roll-out starting now!
  1. wmm
    KitKat Oct 1, 2015
    wmm , Oct 1, 2015 :
    Reboot in safe mode (long-press the power button, then long-press the "power off" selection in the menu), then reboot normally. This has been reported to restore the "close all" button.
    otto2 and vicky_kirar like this.
  2. pgidia
    Lollipop Oct 1, 2015
    pgidia , Oct 1, 2015 :
    Some apps data get cleared automatically after restart
    Some app like MT4 which saves my login id and password gets blank when mobile restart
    The app becomes like it has been downloaded afresh.
    Any solution to this
    @Helen @Mike
  3. tomer.bz
    Cupcake Oct 1, 2015
    tomer.bz , Oct 1, 2015 :
    I am also having some weird issues since the Oxygen 2.1.0 OTA I got last night.
    Cell phone carrier is no longer showing up properly, it just shows as a number "30220". The reception also feels worse, loosing reception / dropping out:
    Battery life seems to be much lower than before. At 85% before, I would still have ~ 19 hours, on basic usage days.
    Help please.
  4. determinator
    Ice Cream Sandwich Oct 1, 2015
    determinator , Oct 1, 2015 :
    Yes, in Belgium too, same symptoms. KPN owns Base and Orange (ex France Télécom) owns Mobistar. That's no justification, but at least there is some consistency in how mistakes are made.
    Also, I was lauding the update until I discovered that it might have killed data connectivity on Slot 1 of the dual SIM system. So I have kinda gone back to the OPO, plus the fingerprint scanner, but minus NFC.
    Thanks OnePlus, you never miss a trick...
  5. Gatorcracker24
    US Brand Ambassador Oct 1, 2015
    Gatorcracker24 , Oct 1, 2015 :
    How much longer until the next update comes out I love oxygen I just want the lag and bugs to go away.
    Hellgamer likes this.
  6. dynrambo
    Eclair Oct 1, 2015
    dynrambo , Oct 1, 2015 :
    Look, if they would like to be out with the Marshmallow in decent time, they will have to start coding right away. They have probably been working on it the last couple of months - so yes, instead of spending a lot of time patching up old Android versions, I would suggest putting focus on the newest build.
    That would also enable OnePlus to take full advantage of the fingerprint scanner, increase battery life etc.
    Battery life is one of the things that users have rated as being important, and Marshmallow promises significant improvements.
    otto2 likes this.
  7. sagar_dragon
    Donut Oct 1, 2015
    sagar_dragon , Oct 1, 2015 :
    Thanks for the update but the gestures on my phone aren't working. Can you share a patch for that. i certainly think this must be a software issue. My phone is new out of box and i have used it just once and checked for gestures which didn't work.
  8. dhruvmittal38
    Froyo Oct 1, 2015
    dhruvmittal38 , Oct 1, 2015 :
    I can't find it . I'm on the normal photo mode . no flash turn on or.off option
  9. abhishek.sharma
    Honeycomb Oct 1, 2015
  10. jmudrick
    jmudrick , Oct 1, 2015 :
    Turn off Beauty, HDR, and Clear Image
    otto2 likes this.
  11. Nbnaturally
    Froyo Oct 1, 2015
    Nbnaturally , Oct 1, 2015 :
    Yea, marshmallow is going to be huge. I can't wait for it. Hopefully we get it soon. As for problems with phones, mine is working flawlessly. Don't see why other users are having issues.
  12. SherwinF
    Gingerbread Oct 1, 2015
    SherwinF , Oct 1, 2015 :
    Works on 360 security
    iDreams7 likes this.
  13. animous
    Froyo Oct 1, 2015
    animous , Oct 1, 2015 :
    Any news on how to mute shutter sounds while recording? For example like snapchat?
  14. rdvikas
    Cupcake Oct 1, 2015
  15. rdvikas
    Cupcake Oct 1, 2015
  16. michael.thier
    Donut Oct 1, 2015
    michael.thier , Oct 1, 2015 :
    i also have this problem
    and also when i want to watch snapchat videos
  17. svales
    Cupcake Oct 1, 2015
    svales , Oct 1, 2015 :
    Nice Job guys.. Keep the good work. My Opo2 is now running oxygen 2.10 smoothly
  18. garvit.chhabra26
    Cupcake Oct 1, 2015
    garvit.chhabra26 , Oct 1, 2015 :
    My op2 camera crashes after this 2.1.0 update. It starts working after a reboot. Really irritated by this.
    Whenever i open the camera a black screen appears n the camera closes by itself.
  19. ahousley86
    Froyo Oct 1, 2015
  20. envyram
    envyram , Oct 1, 2015 :
    Surprising; I don't Seem to have this issue..
