353
OxygenOS 2.1.0 OTA roll-out starting now!
  1. walstylez
    Eclair Oct 5, 2015
    xTlex likes this.
  2. Alex N
    Cupcake Oct 5, 2015
    Alex N , Oct 5, 2015 :
    A2001 - Chinese model
    A2003 - European and Asian model
    A2005 - US model
    That means you have bought the Chinese model and it be flashed O₂OS. Chinese model running on H₂OS.
  3. colorline
    Cupcake Oct 5, 2015
    colorline , Oct 5, 2015 :
    Hello world, this my feedback about the last Oxygen Os update 2.1.0. Build A2003_14_150919
    First i have use the automatic OTA update (not the zip manual file).
    After the update i have clear the app cache of my FB app. No fb issue on my primary account (i explain that in follow).
    I use the latest FB app build 48.0.0.28.137.
    I don't have big issue on this OxygenOs and this build its nice but i have 2 issues and i hope its fix in next update.
    Ok let's go....
    ISSUE #1:
    I use 2 simcard, when i disconnect the card number 2, my OxygenOs crash and my wallpaper its reset, i do reboot my phone and its good. Same thing when i connect "activate" with the sliders in the parameter options.
    ISSUE #2:
    I use 2 android profile (users) on my phone and i switch between my personal and my pro account with the users options. I have two different fb account. 1 perso and 1 pro in my users android mode.
    When i switch and use my users number 2 and when i use my fb app, fb crash when ii click on a friend name to see the profile, or when i click on my fb profile, i have a ctd.
    See in video:
  4. X_mg
    Froyo Oct 5, 2015
    X_mg , Oct 5, 2015 :
    would be cool if there would be a software option to reverse the hardwareslider for the alert options on the next update :)
  5. craigmoore
    Cupcake Oct 5, 2015
    craigmoore , Oct 5, 2015 :
    I can't help but feel I've took a step backwards here. Bought the OPT, battery isn't as good as the one, features missing, even the alarm and ring tones are missing, and loads of buggy problems.
    Released too soon perhaps?
    tomjooonas likes this.
  6. vinpilu
    Gingerbread Oct 6, 2015
    vinpilu , Oct 6, 2015 :
    Send your favourite alarm and ringtones via bluetooth from OPO to OPT and move them to the Alarm and Ringtones folders. They will be on the list when you are going to change the sound.
  7. d33pkwatra
    Eclair Oct 6, 2015
  8. Wasekrules
    Cupcake Oct 6, 2015
  9. svash
    svash , Oct 6, 2015 :
    Thanks. Was about to ask that question of model versions!
  10. rpowel2
    rpowel2 , Oct 6, 2015 :
    im a little confused. With ppl who are rooted and are using twrp, what method do they use to install the Update? Because you obviously cant install using twrp. Are ppl not using twrp recovery anymore?
  11. rpowel2
  12. rdimaggio7
    Cupcake Oct 6, 2015
  13. ormer
    Cupcake Oct 6, 2015
    ormer , Oct 6, 2015 :
    No. I've never seen any kind of "grounding issue" with my OP2.
  14. panjwaniprashant
    Cupcake Oct 6, 2015
    panjwaniprashant , Oct 6, 2015 :
    Please improve your OS, it's super buggy. It's just been 10 days I had oneplus2, and I already had to reset 3 times. Oneplus launcher just hangs and very often says One plus launcher is not responding.
    Gestures needs to be improved. In nutshell a lot of scope of improvement and a long way to go.
  15. wmm
    KitKat Oct 6, 2015
    otto2 likes this.
  16. wmm
    KitKat Oct 6, 2015
    wmm , Oct 6, 2015 :
    I don't know what's causing your problems, but I haven't seen any of those on my OP2.
    otto2 likes this.
  17. wmm
    KitKat Oct 6, 2015
    wmm , Oct 6, 2015 :
    Six hours of screen-on time in a day is not "terrible," and it's better than what I was hitting with CyanogenOS.
    otto2 likes this.
  18. mortonra
    Cupcake Oct 6, 2015
    mortonra , Oct 6, 2015 :
    Has anyone gone from a Nexus 5 to the OnePlus 2? Thoughts and recommendations?
    Thanks :D
  19. randomjen
    Cupcake Oct 6, 2015
    randomjen , Oct 6, 2015 :
    I have the OnePlus one and the OnePlus 2. I am wondering when simple apps like SnapChat and other apps like Adobe new apps will be usable on the OnePlus 2...It works on the one(CM 12?) what is the deal?
  20. anidotnet
    Cupcake Oct 6, 2015
