353
OxygenOS 2.1.0 OTA roll-out starting now!
  1. keatliang2005
    Eclair Oct 11, 2015
    keatliang2005 , Oct 11, 2015 :
    Anyone experience GPS Fix/Lock lost while using WCDMA(3G/HSPA).
    the GPS Lock is back when using 2G or turn off mobile data
  2. alexsirgool
    Gingerbread Oct 11, 2015
    alexsirgool , Oct 11, 2015 :
    When is 2.2 rolling out lol
  3. PrajwalK
    PrajwalK , Oct 11, 2015 :
    Can
    Can you please tell me the difference. In what ways is that different than oxygen os fingerprint?
    DjonniDK likes this.
  4. Deactivated User
    Oct 11, 2015
  5. caribo
    caribo , Oct 11, 2015 :
    How is this an issue exactly? what pain is it causing you ????
    it's merely a visual effect !
  6. Sidekick92
    Cupcake Oct 11, 2015
  7. Manas Eapen
    Jelly Bean Oct 11, 2015
    Manas Eapen , Oct 11, 2015 :
    Hi @Helen :)
    Thank you for the update.
    Please consider for the future update:
    -toggle switch for 2g/3g/4g in notification drawer.
    -an improved data on/off toggle switch in notification drawer.
    -flash light is buggy, both when using as a flashlight and as a flash in camera.Please do the needful.
    -focus hunting in video capture.
    -please include ' live display ' .
    I know you guys are working very hard to make oxygen as pure as possible.I would like to thank you and your team :) for the good work.
    God bless.
    Manas
  8. andreimercan
    Froyo Oct 11, 2015
    andreimercan , Oct 11, 2015 :
    Please consider better battery life..it's not that bad, but i expected more than that. Other than that, my op2 works perfect. Looking forward to the next update
    kables likes this.
  9. addy005
    candyaurelio and otto2 like this.
  10. BitterHoney
    Honeycomb Oct 11, 2015
    BitterHoney , Oct 11, 2015 :
    When is the next update going to roll-out ? Expecting Marshmallow in next OTA..
    So far I found one bug, that is a camera bug.
    When capture photos in dark place with low brightness, the screen goes unresponsive and need to lock and unlock the device to make it normal. Please fix this one in next update.
    Hopefully it would be Android M 6.0...
  11. BitterHoney
    otto2 likes this.
  12. otto2
    Photography Expert Oct 11, 2015
    otto2 , Oct 11, 2015 :
    Push more thgan 5 seconds in video mode on the focus point, than the focus should get locked.
    PrajwalK and Manas Eapen like this.
  13. Ynotsuper
    Ynotsuper , Oct 11, 2015 :
    Thanks. Problem solved. Still have problem with Amazon app though. . .
  14. ngaunguyens
    ngaunguyens , Oct 11, 2015 :
    It is much more sensitive and accurate? Try it and you will see lol
  15. Manas Eapen
    AF/AE locked :).
    I didn't know this..
    Thank you :)..
    Manas
    PrajwalK and otto2 like this.
  16. otto2
    You re welcome.
    Manas Eapen and PrajwalK like this.
  17. dhruvmittal38
    Froyo Oct 11, 2015
    dhruvmittal38 , Oct 11, 2015 :
    I've inserted just one sim. On the Locke screen top left it says emergency calls only half the time and rest of the time it shows Vodafone. I get network through out the day though.
  18. olaray999
    Eclair Oct 11, 2015
    olaray999 , Oct 11, 2015 :
    Please find below the link to the full rom for oxygen os 2.0.2.
    https://www.androidfilehost.com/?fid=24052804347806032
    You will not be able to do the full system backup using the built in recovery unless you have TWRP recovery installed. The backup in this case will be a manual backup of your files, like music and video folders if you have any. You can also take a backup of your messages using sms backup and restore app which is available from the playstore.
    The full rom is about 1.1GB and you need to place this at the root of the internal storage of the OP2.
    You then boot into recovery by holding the volume down and the power button together for a few seconds. Once you in are recovery you should see an option for install from usb, use the vol up and down to highlight and the power button to select, you should see the file you place at the root. Select to install and once it finished, reboot the phone.
    You should now be back on Oxygen OS 2.0.2. This is the way i did mine and did not lose any data and now all my apps are working again.
    Good luck.
    hugogamelas likes this.
  19. olaray999
    Eclair Oct 11, 2015
    InDiSent likes this.
  20. Gaudon
    Eclair Oct 11, 2015
    Gaudon , Oct 11, 2015 :
    I'm assuming all newly ordered devices like my own will come with this version pre-installed?
