353
OxygenOS 2.1.0 OTA roll-out starting now!
  1. hushensavani
    Ice Cream Sandwich Sep 22, 2015
  2. Pratik Mhatre
    Gingerbread Sep 22, 2015
    Pratik Mhatre , Sep 22, 2015 :
    Is thr any solution
  3. SherwinF
    SherwinF , Sep 22, 2015 :
    Ok because the issue happens when the phone is unlocked
  4. mayankjain11
    Cupcake Sep 22, 2015
    mayankjain11 , Sep 22, 2015 :
    I am facing the same issue, have you received any solution for thisTHIS?
  5. Deactivated User
    Sep 22, 2015
  6. 59.aditya
    Froyo Sep 22, 2015
    59.aditya , Sep 22, 2015 :
    i noticed a bug in one plus two.. let me know if you notice the same.
    1) turn on finger print scanner.
    2) then double tab on screen or press power button, so that the screen is turned on..
    3) now place a wrong finger on scanner. It will say 'Try again' on screen
    4) try it 3 times, it will unlock the phone
    drmrahul and harsh.garena like this.
  7. kapil07
    kapil07 , Sep 22, 2015 :
    i had a similar issue, and even fb update was not getting installed.... Clearing playstore cache un-install fb, reboot and reinstall fixed it
    veryannoyingname likes this.
  8. SaminOz
  9. mayankjain11
    Let me try this
  10. barrymaldon
    Eclair Sep 22, 2015
    barrymaldon , Sep 22, 2015 :
    Not for me, after three times it brings the password screen unlock image and after another failed fingerprint attempt it will lock that option and you will only be able to unlock via the password prompt page...
  11. Nabura
  12. SherwinF
    Yes, I agree and am experiencing the same thing.
    Some people don't use locks on their phone when in a safe place like their home or car. If you use the fingerprint scanner, it should turn the screen on regardless of whether the phone is locked or not.
    SimonFullerImagery likes this.
  13. pedroniu
  14. geraldkoerner
    Eclair Sep 22, 2015
    geraldkoerner , Sep 22, 2015 :
    As I can unlock the phone using my fingerprint, I dont see any reason why I should NOT lock my phone, regardless whether I am at home, in my car oder anywhere else...
  15. So_ony
    Community Veteran Sep 22, 2015
  16. Dunnow
    The Lab - OnePlus 6 Reviewer Sep 22, 2015
    Dunnow , Sep 22, 2015 :
    try forcing an update on android web view + google play services and make sure you run the latest Facebook build. I had this issue like a month ago on my Nexus 4, both andriod web view and google play services updates AFTER facebook did, and once they did, it started working as if nothing. Might be related to that, maybe.
    @peoplesflip
  17. 59.aditya
    Froyo Sep 22, 2015
    This was because my phone was connect to smart watch which was trusted. by default it keeps the phone unlocked if connected to smart device. i had to go to advanced settings to turn that feature off.
  18. harsh.garena
    harsh.garena , Sep 22, 2015 :
    You my friend are a genius ;) Wait for FBI's Invite to hire you soon :D U just cracked the Illuminati Firewall :p
    59.aditya likes this.
  19. 59.aditya
    Froyo Sep 22, 2015
    Sarcasm level : God like :d
    harsh.garena likes this.
  20. Beta_Bhavya
    Donut Sep 22, 2015
