353
OxygenOS 2.1.0 OTA roll-out starting now!
  1. yash rawal
    Froyo Sep 23, 2015
    yash rawal , Sep 23, 2015 :
    just an invite to buy a phone nothing else i want if possible roll out invite in big amount currently i am phoneless
  2. bgm13
    Froyo Sep 23, 2015
    bgm13 , Sep 23, 2015 :
    @Helen would it be possible to outline the rollout plan? So people in the various regions know when to expect it?
  3. doomsd4y
    Gingerbread Sep 23, 2015
  4. jcespi2005
    Ice Cream Sandwich Sep 23, 2015
    jcespi2005 , Sep 23, 2015 :
    Messenger application don't rotate, it's not related to keyboard. Use the Google hangouts as SMS app...
    This is not an issue ;)
  5. more.darshan
    Cupcake Sep 23, 2015
    more.darshan , Sep 23, 2015 :
    it did not rotate even before 2.1 update.
  6. wmm
    KitKat Sep 23, 2015
    wmm , Sep 23, 2015 :
    Maxxaudio stops working after a day or so. (This isn't new, I noticed the same thing on 2.0.2.) I'll open Pandora or play a video and note that the volume is low; going into Maxxaudio and toggling it off and on makes no difference in the sound. A reboot restores it, after which toggling it off and on makes a very marked difference in both volume and richness.
    I wonder if this is the explanation for the people who are saying that their volume is too low? I agree, when Maxxaudio isn't working, the volume is inadequate, but I find it quite loud when Maxxaudio is functioning.
  7. Dunnow
    The Lab - OnePlus 6 Reviewer Sep 23, 2015
    Dunnow , Sep 23, 2015 :
    I've got the OTA the same day it's announced, directly to my phone 30 MB download instead of thw whole image... I'm tired of unlocking bootloaders and manually doing everything... I just want it to work.
    They should give us the option to change DPI, or do it themselves. This Os looks made for a child. It's just plain dumb... every single entry on settings menu is bigger than my thumb...
    They should also spaciate icons more than they do on the launcher... it looks cluttered AF
    Chugz and Ales like this.
  8. healingparadise
    Donut Sep 23, 2015
  9. danduf1981
    Honeycomb Sep 23, 2015
  10. wmm
    KitKat Sep 23, 2015
    Not for me. What mode are you using? In Clear Image mode for me, the delay after pressing the shutter button is about a quarter of a second, I'd estimate.[/QUOTE]
  11. wmm
    KitKat Sep 23, 2015
    Odd. I get a "missed call" notification on my lock screen and the bounced-arrow icon in my notification bar, and the call history in the dialer shows a red arrow pointing down and to the left for the missed call (just tried it). Not sure what could account for the problem you're having, but it all seems to work as intended for me.
    otto2 likes this.
  12. otto2
    Photography Expert Sep 23, 2015
    otto2 , Sep 23, 2015 :
    A bit more reading would help to understand, that COS12 is the official supported OS for the Oneplusone. So ask Cyanogen Inc. If you want an Update. Oxygen 1 was only brought as needed alternative.
  13. jcespi2005
    The only thing don't work for me is the "restart" option down the screen... the rest is working fine for me (using with powerAMP one hour a day, BT headset music).
    Anyway, if turn off the MaxxAudio, the volume is good, lower but enough..
    Perhaps you should try a factory reset...
  14. Legitti
    Froyo Sep 23, 2015
  15. jcespi2005
    You don't need to wait, just download the OTA ZIP, and install on stock recovery ;)
  16. dpbrady12
  17. bassopt
    bassopt , Sep 23, 2015 :
    You're right but actually CM is probably the few Roms that let you change Dpi without root. No stock rom from any manufacturer has this option . To avoid app compatibility problems I guess....
    Chugz likes this.
  18. termina24
    veryannoyingname and mav2000 like this.
  19. Sushanth Gopal
    Sushanth Gopal , Sep 23, 2015 :
    Hi Helen,
    The update looks good as of now. Manual mode in Camera is just awesome. However, FB is not opening in my OPT after I installed the Oxygen 2.1.0. I even tried updating the FB. But, no response.
    One more request from my side is font options. I am a huge fan of Roboto Condensed because it can take less space and more text.
    I am eagerly waiting for font options in my OPT.
    jcespi2005 likes this.
  20. Ales
    Eclair Sep 23, 2015
