195
OxygenOS 2.1.1 update will roll out today
  1. Sr Vincenzo
    Ice Cream Sandwich Oct 15, 2015
    Sr Vincenzo , Oct 15, 2015 :
    Dirty Flash the full 2.1 ROM in TWRP over the current system (little over a g) then flash the OTA 2.1.1 file, flash SuperSU, wipe dalik and cache, reboot.
    As always make sure you have at least 50% battery, I did mine while at 75%
    alexbartok likes this.
  2. alex inthi
  3. alexbartok
    Honeycomb Oct 15, 2015
    alexbartok , Oct 15, 2015 :
    Isn't there anyway to unroot...? I don't want to loose my apps/data...
  4. cedalone
    Jelly Bean Oct 15, 2015
    Chika likes this.
  5. saminpgh
    KitKat Oct 15, 2015
  6. shuranaga
    shuranaga , Oct 15, 2015 :
    Yes, this OTA is OK, but never had any of the issues to be fixed with it, so probably will wait for 2.2 OTA :)
  7. fhkieft
    Froyo Oct 15, 2015
    fhkieft , Oct 15, 2015 :
    What I don't understand that they, one plus, did not atmit that the problem fb was caused by them. Would have saved a lot of costumers stress. Got the feeling that all energie is stuck in op3. And they drop 2 like they did with one
  8. bsturm
    Eclair Oct 15, 2015
    bsturm , Oct 15, 2015 :
    I received the update but when I install it the reboots and I'm still on 2.1.0 please assist.
  9. joesweeney413
  10. Rebekah
    Gingerbread Oct 15, 2015
    Rebekah , Oct 15, 2015 :
    It's the only thing that I've changed on my opt, and that's the launcher. I'm using Action 3 launcher and then you can have your screen however you want it without disabling anything. Nova launcher is good too.
    We've all been asking for the removal of the search bar on Oxygen so I'm sure OnePlus will be bearing it in mind.
  11. prabhus67
    Cupcake Oct 15, 2015
    prabhus67 , Oct 15, 2015 :
    I
    I need your help to update this OTA. It says I cant update it as the phone is rooted. Even if I unroot it the upgrade stops showing a Chinese error. I have tried several terms and the same result. Can some one kindly help if you updated this with out any problem. Many thanks
  12. fabiansebulke
  13. azart
    azart , Oct 15, 2015 :
    FB worked for me on 2.1.0 superb! Do not understand such type of update...
    Maghuro, Chika and shuranaga like this.
  14. Maghuro
    Maghuro , Oct 15, 2015 :
    Only those "fixes"? lol
    I mean.. The most important thing to fix on this software is... Facebook!
    I'm in love <3
    Chika likes this.
  15. jcespi2005
    jcespi2005 , Oct 15, 2015 :
    This is a known behavior when your battery go <20% so charge it and you're done ;) it's not an issue...
    otto2 likes this.
  16. abvage
    Eclair Oct 15, 2015
    abvage , Oct 15, 2015 :
    Anyone having whatsapp bug after update!! It cannot recognize my contacts.. :(
  17. jcespi2005
    Works fine for me
    abvage and otto2 like this.
  18. Sr Vincenzo
    You won't lose any data. There's a thread or 2 on here that contains the full 2.1 ROM and another that has the new OTA zip. Just follow previous instructions and you're good to go
    otto2 and alexbartok like this.
  19. alfonso.lopez08
  20. SilentDecode
    Donut Oct 15, 2015
    SilentDecode , Oct 15, 2015 :
    Not an update I'm needed to apply. There aren't enough changes, to repeat the process of a rooted phone :p
    Maghuro likes this.
