195
OxygenOS 2.1.1 update will roll out today
  1. alperion37
    Eclair Oct 16, 2015
    alperion37 , Oct 16, 2015 :
    What the point, they still haven't fixed the core issue, which is unresponsiveness to touch.
  2. alperion37
    Eclair Oct 16, 2015
    CM/COS are awesome. I wish they had one for OPT. Oxygen OS is terrible right now. Each update worse than the previous. I'm still running off 2.0.2
  3. jishant.sukhija
    Cupcake Oct 16, 2015
    jishant.sukhija , Oct 16, 2015 :
    PLEASE HELP ME WITH FEW THINGS IF YOU CAN:
    There are few things I am not able to do or see in my One plus 2 device:
    1. There's only one icon pack visible 'System Default', no other icon pack. Although I read it has three pre-installed icon packs.
    2. I am not seeing any home option in my settings, and thus not able to remove google search bar from home screen.
    3. In Settings>Customization, accent color option is disabled. I am not allowed to change.
    Please help with these problems? Does this device comes with these privileges only?
  4. Thanasis Kalatheris
    Eclair Oct 16, 2015
    Thanasis Kalatheris , Oct 16, 2015 :
    i charge it during the night and when i wake up i take it and go to class(university) i dont consider it a "stress"
  5. sergioreja
    Honeycomb Oct 16, 2015
  6. Deactivated User
    Oct 16, 2015
  7. hkgoh
    Ice Cream Sandwich Oct 16, 2015
    hkgoh , Oct 16, 2015 :
    I need my flashlight back.
  8. vibhorbhatnagar
    vibhorbhatnagar , Oct 16, 2015 :
    Hi I also have the same issue before update my antutu score was 54063, but after it got reduced to 43031. Hope they fix this soon.
  9. squall458
    Eclair Oct 16, 2015
    squall458 , Oct 16, 2015 :
    Same here. My antutu score is much lower. How is that possible?
    stevenchow90 likes this.
  10. vinpilu
    Gingerbread Oct 16, 2015
    vinpilu , Oct 16, 2015 :
    1.there are no pre-installed icon packs, but after you install some from play store, they will be on the list.
    2.afaik,the google search bar cannot be removed at least from menu / settings. Maybe after root and some hack.
    3.well that's strange, should be work...
  11. Mikey160984
    Mikey160984 , Oct 16, 2015 :
    The brightness Sensor still got weird behavior many times...
    Suddendly, when its Dark, and a little light comes from somewhere, for just a second, the display gets very bright for a short time, and the goes back to lower brightness
  12. jpjaspreetmahal
  13. jishant.sukhija
    Removing google serach is the biggest constraint without being a root user. It's really annoying. Will have to get a launcher.
  14. fxguru77
    Jelly Bean Oct 16, 2015
    fxguru77 , Oct 16, 2015 :
    No such problems here maybe its your device.ju
    Just iinstall an other launcher
  15. Sourav Parija
    Sourav Parija , Oct 16, 2015 :
    Which version are you using? and what you suggest should i update?
  16. playkish
  17. stevenchow
  18. biki636
    biki636 , Oct 16, 2015 :
    This is not cool, you were bitching about OPO the whole last year, and now that OP2 is out, you don't give a crap about OPO?
  19. kankung
    kankung , Oct 16, 2015 :
    After update 2.1.1 one plus launcher keep crashing.....looks like the update creates more bugs
  20. fespacio
