195
OxygenOS 2.1.1 update will roll out today
  1. groundziro
    Froyo Oct 16, 2015
    groundziro , Oct 16, 2015 :
    It is normal for rooted users. The simplest way to update is to dirty flash the full Oxygen OS 2.1.1 ROM (not the OTA update). It has not been made available for download yet. We must wait.
    The other option is to revert to stock 2.1.0 (losing root), and then apply the OTA update.
    Personnally, I'm not sure whether there is loss of personal data with that option, and I don't want to deal with the hassle of temporarily reverting to stock 2.1.0; So I will wait for the full ROM .zip to be released.
    ajayhirapara likes this.
  2. anlariosus
    Donut Oct 16, 2015
    anlariosus , Oct 16, 2015 :
    I did revert to stock 2.1.0 with TWRP and installed the OTA 2.1.1 from TWRP also and I did not loss any personal data, and my apps are still there!, this is awesome!
    TWRP allows you to select up to 10 ZIP files to install as a batch. Just pick them in the appropiate order:
    1.- Select the ZIP for Stock 2.1.0
    2.- Select the OTA zip for 2.1.1
    3.- Select the ZIP for Rooting
    TWRP will run the installations in that order. Just remember to do the WIPE before (it wont delete personal data either, it only wipes cache, dalvik and system)
    ajayhirapara and groundziro like this.
  3. Gulbuddin
    Froyo Oct 16, 2015
    Gulbuddin , Oct 16, 2015 :
    You cant remove the search bar.. Use custom launchers if you want to remove it.. Like nova or any other. Icon pack is only one. You can install others though. And in order to select accent color turn theme to dark first
  4. Gulbuddin
    Froyo Oct 16, 2015
    Mine is rooted under clocked and greenified. So it last really long
  5. anlariosus
    Donut Oct 16, 2015
    This is how:
  6. anlariosus
    Donut Oct 16, 2015
    @Helen: Every update you do is great, but I am desperatelly wating for a mayor Camera upgrade, there is still a lot of work to do with this matter!
  7. GP2261
    Cupcake Oct 16, 2015
    GP2261 , Oct 16, 2015 :
    What about oneplus one ota updates.. We are still.waiting.. Give some proper cut off
  8. miv3180
    Froyo Oct 16, 2015
  9. pratikg88
    Honeycomb Oct 16, 2015
    pratikg88 , Oct 16, 2015 :
    Thanks for the quick fix. I also wants point out one thing. Sometimes Oneplus launcher get crash. It happened with me 4-5 times after 2.1 update till now. Please look into this as well if you have not in 2.1.1
  10. Fikri
    Gingerbread Oct 16, 2015
    Fikri , Oct 16, 2015 :
    Thank You for the update. Hope that we Will have an update soon which makes it possible to change the dpi.
  11. sen2015
    sen2015 , Oct 16, 2015 :
    I also own opo since jan15, and that is best phone on cyanogenmod. It was initially on cm11s but I rooted that and flashed oxygen 1.0 but this was a terrible experience. Then I further came back on cm12. Now it is fantastic. If you are on cm then don't request for oxygen. You are on best rom.
  12. bunbunwang
    bunbunwang , Oct 16, 2015 :
    I'm currently having the issue where group texts messages are not in the same text. Ie. I will have 2 groups with 1 person responding while the other 2 would be in a totally different group.
  13. kirar
    kirar , Oct 16, 2015 :
    wtf after updating my WiFi got connect disconnect automatically.......
  14. Muralisankar87
  15. Muralisankar87
    Muralisankar87 , Oct 16, 2015 :
    I am Newbie to rooting, What's AK?
  16. spencer1620
    Ice Cream Sandwich Oct 16, 2015
    spencer1620 , Oct 16, 2015 :
    Yes that happened to me. I reflashed and it was fine
  17. yk89
    yk89 , Oct 16, 2015 :
    This update has broken the most important thing for me!
    No longer able to connect to vpn using pia app. Please fix asap.
    Anyone else having the same prob?
    rungem likes this.
  18. DeFQoN_1_469
  19. DeFQoN_1_469
    DeFQoN_1_469 , Oct 16, 2015 :
    Fixes
    - sometimes my alarm has no sound
    - the button for close recent apps disappears included the google bar and sometimes the google bar but the button for to close everything stands
    *Sugestions- more camera improvements (13mp by 16:9, faster focus, ...)
    - more gestures, custom gestures (C for calculator as example)
    - lcd density settings (i really need this, i like to use 400 dpi)
    - alert slider settings (vibrate mode for all notifications)
    - customizable shortcuts on lockscreen
    - status bar settings (clock position, ...)
    - notification drawer need to be more customizable (more shortcuts, advanced location settings, hide brightness slider, )
    - more led notification colors and to choose wich app has wich colorl
    - unlimited adapted profiles in audio tuner
    - home button in chrome
    - next track and previous trach with volume buttons when device is locked
    - power saving mode
    - extreme power saving mode (black & white)
    - air gestures (wave to see notifications) [if possible]
    - voice recorder
    - android auto (eu)
    - lock selected apps (ex. Gallery app that you will need to unlock with fingerprint scanner)
    - vibrate intensity
    - option to hide google search bar in recent apps
    - change the brightness of the capacitive buttons
    - transparant camera app
    - calculator history
    - quickcharge [if possible]
    - able to change the lockscreen wallpaper
    - slider for turning off or on of maxxaudio
    - capable of using 2 apps at the same time
    - fm radio
    - clock & weather widget
    - audiotuner profile shortcuts for on my homescreen
    - a settings button in the sound popup when you change your volume so you can switch easy to notifications or alarms, so it's easy to adjust it, that you always have to go to settings and then go to sound settings for adjusting them
    klogmooz likes this.
  20. yuganathan
    Gingerbread Oct 17, 2015
    yuganathan , Oct 17, 2015 :
    When can v get updates for battery life and power save mode option.
