147
OxygenOS 2.1.2 will start roll-out to OnePlus X today
Thread Status:
Not open for further replies.
  1. asharma0085
    Eclair Nov 11, 2015
    asharma0085 , Nov 11, 2015 :
    Hi, I have one plus x, I am having few questions to be asked. Please reply as iImentioned confused with it.
    1. How many speakers are there in oneplus x. As there are two speaker grills at the bottom. But when tried covering each one by one, i found that left speaker is only producing sound and not the left one. Is this a hardware issue?
    2. Anybody has installed candy crush on oneplus x cause when i installed it its not loading and crashes after few minutes.
    Please help anyone.
  2. sunnyshaan
    Honeycomb Nov 11, 2015
    sunnyshaan , Nov 11, 2015 :
    Please fix the storage bug (SD card). Can't change storage to SD card in camera and can't transfer apps to sd card which is quite annoying.
    michaelliao07 and gregorcerar like this.
  3. jitheshk
    Froyo Nov 11, 2015
    jitheshk , Nov 11, 2015 :
    There is only one speaker.Other one is a mic.
    Game crash is due to the famous oxygen OS
    michaelliao07 likes this.
  4. Aditya Wasan
    Gingerbread Nov 11, 2015
    Aditya Wasan , Nov 11, 2015 :
    Same Here I'm On Sultans MM And Its Working Awesome.
  5. Aditya Wasan
    Well There's No Problem For Me As I'm Running MM On My OPO But The Problems Are For The Ones Who Don't Know How Yo Root... Because OP Promised Updates For 2 Years After Breaking Up With Cyanogen
  6. yetiweston
    Ice Cream Sandwich Nov 11, 2015
    yetiweston , Nov 11, 2015 :
    Sorry if I have missed this somewhere but is there a flashable link for the OTA for people who are rooted etc?
  7. Aditya Wasan
    So You Must Be Promising The Cyanogen M Update For OPO...... OP Build OOS So That If Cyanogen Does Not Give Update We Have Other Alternatives BTW Even OP Is Not Supporting OPO.... Giving Updates For One Verison Of The OS Doesn't Mean That The Same Will Happen To The Next Version.
  8. gertjanodink
    Cupcake Nov 11, 2015
    gertjanodink , Nov 11, 2015 :
    I don't know if this is the right place, but i'll give it a try. I seem to have a problem, which happened after this update. None of my sounds work ( slider is set to getting all notifications ), music wont work, app sounds etc. Only thing that does work communication by phone. Anyone else that has this problem, or knows how i can fix it?
  9. Arjun.Dhawan1401
    Donut Nov 11, 2015
  10. geko95gek
    geko95gek , Nov 11, 2015 :
    Ooh I need to have a look through the dev section again. Last time I looked it was bare lol
  11. asharma0085
    Eclair Nov 11, 2015
    Can the candy crush crashing can be fixed? Have any solution for it.
  12. Koh_XuMing
    Eclair Nov 11, 2015
    Koh_XuMing , Nov 11, 2015 :
    I have a OPO. I flashed my ROM to Oxygen OS 1.0 recently. I always check to software update in system but there is always no update. Now Oxygen OS 2.0.2 is even released. How do I get automatic updates for oxygen os? Must I always flash my ROM? This is so freaking troublesome.
  13. JuStAdsor
    Donut Nov 11, 2015
    JuStAdsor , Nov 11, 2015 :
    Hi,
    Any news regarding the SDCARD fix?
    Thank you!
  14. Ekansh.c
    Eclair Nov 11, 2015
    Ekansh.c , Nov 11, 2015 :
    i have an one plus x and for some reason i am not getting my USSD notifications after i end my calls or end the internet session. any one else facing the same issue?
    Anyone whi knows how to fix it?
  15. Balkers
    Balkers , Nov 11, 2015 :
    Patient.... OnePlus is working on it..see earlier posts. SDcard is visible in filemanager and via connection cable on PC
  16. TheUncannyOne
    Froyo Nov 11, 2015
    TheUncannyOne , Nov 11, 2015 :
    This is a OnePlus X update? Don't see why you're complaining in a OnePlus X thread.
  17. ur0
    ur0 , Nov 11, 2015 :
    Can confirm the update. Went fine, seeing significant performance and camera improvements.
  18. JuStAdsor
    Donut Nov 11, 2015
    I have a 64 GB card, and is not visible in file manager at all.
    The card works perfectly on other phones.
  19. qtekfun
  20. yetiweston
    Because regardless of the break up Cyanogen has always been the primary OS of the OPO and Cyanogen is also still committed to supporting it so therefore, the OPO primary OS is and always will be CM
