6
OxygenOS 2.1.4 mod script flash TWRP
  1. tainguyen2704
    Gingerbread Jan 23, 2016
  2. ojaswinsingh
    ojaswinsingh , Jan 23, 2016 :
    Can I add it to my post of "Improving OxygenOS 2.1.4"? Oh and Really thanks for making this :D Just what I needed
    tainguyen2704 likes this.
  3. Tokolozi
    Most Original Avatar Jan 23, 2016
  4. Corvinus77
    Honeycomb Jan 23, 2016
  5. theapu
    Jelly Bean Jan 23, 2016
    pbergonzi and Corvinus77 like this.
  6. Corvinus77
  7. Corvinus77
    Corvinus77 , Jan 23, 2016 :
    Whats the exact procedure for flash this ROM with TWRP 2.8.6.x ?
    Exactly as we know it :
    • Copy the ROM to the Memory of the OPO
    • Boot into TWRP
    • Make a Nandroid Backup (optional)
    • Wipe system + data + cache + dalvik
    • Select Install
    • Chose the ROM .zip
    • Swipe to install
    • reboot the OPO
    Or must be considered something else ??
    Regards
    EzeNofx likes this.
  8. MR.BRIGHTSIDE
    Eclair Jan 24, 2016
    MR.BRIGHTSIDE , Jan 24, 2016 :
    I've try the first post and now my phone is getting error
    No radio,no imei and i cant turn off my phone
    I have try the step carefully
  9. johncel.espares
    Froyo Jan 24, 2016
  10. Dome84
    Gingerbread Jan 25, 2016
  11. AarKay2311
    Froyo Jan 27, 2016
    AarKay2311 , Jan 27, 2016 :
    Will it wipe internal storage? I don't think it will do as we are not messing up with bootloader.. Just wanted to check though
  12. EzeNofx
    Eclair Jan 28, 2016
    EzeNofx , Jan 28, 2016 :
    I have the same question. Please any one can help us?
  13. pbergonzi
    KitKat Jan 28, 2016
    pbergonzi , Jan 28, 2016 :
    Installing a rom should not wipe internal storage, however BACKUP anyway, and just in case. It's easy to transfer your most important things to PC and copy them back later.
    Furthermore, using the official installer for OxygenOS 2.1.4 has an option to "Unlock the bootloader." Using this option will probably erase EVERYTHING on the phone.
  14. EzeNofx
    Eclair Jan 29, 2016
    EzeNofx , Jan 29, 2016 :
    Thnx for ur answer. But im still having the same question. Read corvinus77 cuestión pls. Mbe you can help us with that.
  15. pbergonzi
    KitKat Jan 29, 2016
    pbergonzi , Jan 29, 2016 :
    I apologize--the steps you've quoted make perfect sense to me.
    As an added precaution, after flashing the rom, tap the "Wipe Dalvik and Cache" button, and when it's done, reboot back to TWRP once--then reboot the system.
    Good luck--have fun. Oxygen is gorgeous.
    EzeNofx likes this.
  16. EzeNofx
    Eclair Jan 31, 2016
    EzeNofx , Jan 31, 2016 :
    Everything is perfect. Thnx man. Oxy OS works better than cm 12.1 ( for me ).
    Everything works fine, no bugs, with cm12.1 calls have really bad quality, but now back to normal. Thnx
    pbergonzi likes this.
