3
OxygenOS 2.2.0 Bugs list.
  1. Akshat2793
    Ice Cream Sandwich Dec 22, 2015
    Akshat2793 , Dec 22, 2015 :
    You haven't got the update yet? :O
  2. Akshat2793
  3. charanchakravarthi
    Honeycomb Dec 22, 2015
    charanchakravarthi , Dec 22, 2015 :
    Oh.. That's the problem..!! That was a good catch. BTW, I haven't got the update yet and too stingy to update via recovery too cause my data for the month is one the verge of completion... Will have to go to office tomorrow and then update all the apps and OS too.
  4. jozi
    Froyo Dec 22, 2015
    jozi , Dec 22, 2015 :
    no sir, i tried it 4 times it only takes 270 degrees with a blank area, plus stitching is aweful it wasnt like this.
    i tried with 2 other OPT phones "thought its my unit issue" all on stock 2.2.0 same problem. PHOTO SPHERE gone with the wind.
    thalys and Stephen McGuiness like this.
  5. jozi
    Froyo Dec 22, 2015
    its only a 57 MB :) "didnt expect much after seeing that :)" doubt that it will kill your bandwith for the month
    charanchakravarthi likes this.
  6. Stephen McGuiness
    Gingerbread Dec 22, 2015
  7. jozi
    Froyo Dec 22, 2015
    Someome wrote that he sees only the letter "G" instead of the search bar.
    That is by mistake u disabled the search bar visibility from the launcher settings.
    Hold the multitask key for few sec then go down and enable the search bar visibility :)
  8. jozi
    Froyo Dec 22, 2015
    Please post the screen SOT. Mine dont pass 2:50 :( with battery saver on
  9. agodo
    agodo , Dec 22, 2015 :
    After the update my camera is crashing when I try to open it... Any idea?
    Running ak kernel xposed and root
  10. dinjesk
    KitKat Dec 22, 2015
    dinjesk , Dec 22, 2015 :
    use stock kernel,
    other kernels like AK and boeffla are not working properly
    otto2 and agodo like this.
  11. agodo
    Ice Cream Sandwich Dec 23, 2015
    agodo , Dec 23, 2015 :
    Thanks!! Waiting for boeffla to fix this :)
  12. dinjesk
    KitKat Dec 23, 2015
    dinjesk , Dec 23, 2015 :
    better go to stock first, as boeflla wil go on holliday
    otto2 and doublear like this.
  13. Stephen McGuiness
    Gingerbread Dec 23, 2015
    Stephen McGuiness , Dec 23, 2015 :
    Where will I find the SoT info ?
  14. sanchitd5
    Honeycomb Dec 23, 2015
    sanchitd5 , Dec 23, 2015 :
    Tap on the screen option.
  15. jyubil
    jyubil , Dec 23, 2015 :
    What about LED?
    Stephen McGuiness likes this.
  16. charanchakravarthi
    charanchakravarthi , Dec 23, 2015 :
    It will when you have 300MB free in my 6GB pack especially when the billing cycle only ends by Jan 5th... You see the connection?? :p:p:p
    ButterFlYnez likes this.
  17. 1960
    1960 , Dec 23, 2015 :
    Did you clear the cache from recovery after update?
    Mine is working perfectly fine, 360° full photosphere
    Does your app takes pics of only 270° or after stitching it shows 270°??
  18. jozi
    Froyo Dec 23, 2015
    jozi , Dec 23, 2015 :
    I cleared the cache before and after the update. The 270 is while taking the shit not at the stitching level seems like they messed the gyroscope :(
    Stephen McGuiness and thalys like this.
  19. jozi
    Froyo Dec 23, 2015
    Haha yup true and its not that worth it to be honest :(
  20. jozi
    Froyo Dec 23, 2015
    Go to settings >battery > look for screen and click it . it will show you how much time ur screen was on.
