377
OxygenOS 2.2.0 rollout is starting
Thread Status:
Not open for further replies.
  1. kaihp
    Jelly Bean Dec 31, 2015
    kaihp , Dec 31, 2015 :
    The price difference of a USB3.0 and a USB.20 Type-C connector and a couple of traces? You gotta be kidding me.
    There must be something else behind that decision. Like license costs. Technically, it's a no-brainer.
    otto2 likes this.
  2. SaltLife
    Ice Cream Sandwich Dec 31, 2015
    SaltLife , Dec 31, 2015 :
    No one was furious, I just found it rather ironic that you told me I should read up on things before posting.
  3. 1960
    Honeycomb Dec 31, 2015
    1960 , Dec 31, 2015 :
    UBC C is totally different from USB 3
    Oneplus 2 has UBS C, n I didn't encounter any such message in my PC.
    I receive such notifications for USB 3 devices such as stage devices.
  4. SadButTrue
    SadButTrue , Dec 31, 2015 :
    there is no phone at the moment which is using a full compatible 3.1-C port..
    they all using usb 2.0 internally...
  5. Proking
    Cupcake Dec 31, 2015
    Proking , Dec 31, 2015 :
    My OnePlus 2 starts hanging after new update.
    It stuck for 15 mins and no key works.
  6. SadButTrue
    if it is optimizing apps -> wait this could take quite long
    if it hangs after reboot press powerbutton at least 10 seconds (it will shut down)
    retry booting if it doesnt work go to recovery clear cache and retry
  7. Gunbir
    Gunbir , Dec 31, 2015 :
    I unboxed the phone and installed the newest update (2.2.0) and now the phone settings won't open. I can't factory reset the phone because to do that the settings need to open. What do I do?
  8. eurokidx
    Gingerbread Dec 31, 2015
    eurokidx , Dec 31, 2015 :
    Shut off your phone,and hold Power and Volume Down at the same time, and wipe data and cache
  9. kaihp
    What OS are you using? I get these notifications every time I plug in my OP2 into either a USB2 or USB3(.0) port on my Win7 computers. Tried both using Oneplus' cable and a 3rd party USB3 cable with Type-C connector.
    I never talked about USB 3.1. The Qualcomm part has USB 3(.0) - they advertise this themselves.
    The connector and protocol handling are orthogonal issues. The OP2 is a perfect example of this. The Snapdragon 810 advertises itself as USB3 capable, but when the PC tries to switch to USB-3 mode, it cannot communicate because the OP2 misses the correct wiring.
  10. SadButTrue
    once again nobody is using anyting above usb 2.0 - i don't know why (but i didn't think its an wiring issue) but i can also tell you even google's nexus 6p and 5x does not use usb 3.0 or 3.1 - they are also using a usb 3.1-c port with usb 2.0...
  11. daniii
    Donut Dec 31, 2015
    daniii , Dec 31, 2015 :
    Thank you for fixing the SIM selection bug. Unfortunately I am experiencing a loss of performance with this update. The phone has also frozen, necessitating a forced reboot.
    Proking likes this.
  12. fesleywox
    Froyo Dec 31, 2015
    fesleywox , Dec 31, 2015 :
    Same here
    Proking likes this.
  13. fesleywox
    Froyo Dec 31, 2015
    Exactly that problem with my OP2
    Proking likes this.
  14. Melonconstant
    Donut Dec 31, 2015
  15. Prateekarora98
    Eclair Dec 31, 2015
    Prateekarora98 , Dec 31, 2015 :
    Brightness was at 50% and all time screen was on and i played asphalt 8 for ½hr
    And my update is like 5 days
  16. Prateekarora98
    Eclair Dec 31, 2015
    Yeah and u need a fast charger and software compatible for it and ofc cable too
    Akshat2793 likes this.
  17. krito007
    krito007 , Dec 31, 2015 :
    Wipe the cache partition using volume down key and power button simultaneously
  18. Prateekarora98
    Eclair Dec 31, 2015
    Yeah sometimes that happen with me too but simetimes it doesnt so dont worry on it
    SaltLife likes this.
  19. 1960
    I used my phone on both Windows 7 & 10
    Phone is shown as media device, so no question of USB 3.0 or USB C warnings...
  20. krito007
    After 2.2.0 update there's a bug in maxx audio equillizer .what should I do.
    Does anyone has solutions for this problem
