377
OxygenOS 2.2.0 rollout is starting
Thread Status:
Not open for further replies.
  1. matus198
    Cupcake Jan 2, 2016
    matus198 , Jan 2, 2016 :
    After update I am having same issues like guys above...
    1)Wifi connection - when I want to play game which request connection to the internet (Vain Glory - no advertisement) it say that i am not connected at the internet but I have connect phone to WiFi..
    2) When I restard my device, that direct call "bubble" shows like that green android guy
    That's all with what I've met I would be happy if you could fix it asap!
    Thank you :)
  2. uikeparag
    Cupcake Jan 2, 2016
    uikeparag , Jan 2, 2016 :
    Thank you for reply !
    SaltLife likes this.
  3. Paulosatcunha
    Cupcake Jan 2, 2016
    Paulosatcunha , Jan 2, 2016 :
  4. Paulosatcunha
    Cupcake Jan 2, 2016
    Hi,
    I can´t downloading the 2.2.0, all the time said that had a mistake in download process, what I can do??
    Thanks in advance.
    P.
  5. Javiertru
    Cupcake Jan 2, 2016
    Javiertru , Jan 2, 2016 :
    I think this update is worse than the update 2.1.3 now i have lag and another things
    bokdoyagee likes this.
  6. denona
    Donut Jan 3, 2016
  7. dagario
    Honeycomb Jan 3, 2016
    dagario , Jan 3, 2016 :
    This 2.2.0 is really better than 2.1.2
    Battery life increase and no more bugs on my OP2
    Sahilkum likes this.
  8. faizfuad
    Cupcake Jan 3, 2016
    faizfuad , Jan 3, 2016 :
    how should i do it?
  9. bokdoyagee
    Gingerbread Jan 3, 2016
  10. Jeekulk
    Cupcake Jan 3, 2016
    Jeekulk , Jan 3, 2016 :
    • Added hide search bar option in launcher settings
    Can anyone tell me where I can find this?
  11. ronyjarod
    ronyjarod , Jan 3, 2016 :
    i did the same but the problem is still there
  12. uvdv
    Cupcake Jan 3, 2016
    uvdv , Jan 3, 2016 :
    After updating to version 2.2.0 i have a problem with the direct call widget, after starting the phone the Photos of the contacts had been crossed, is there a solution?
  13. davekern
    Cupcake Jan 3, 2016
  14. kaghedo
    Jelly Bean Jan 3, 2016
    kaghedo , Jan 3, 2016 :
    Hold down the home screen and you will see SETTINGS on your right hand side,click it and you will find the option to hide the search bar ;)
  15. tejas.gupta999
    Eclair Jan 3, 2016
    tejas.gupta999 , Jan 3, 2016 :
    Long-press on an empty space on your homescreen and go to settings, the option is present under the 'Other' category.
  16. dobradani
    Donut Jan 3, 2016
    dobradani , Jan 3, 2016 :
    if they release update like this, with many bugs, i don't have many expectation from marshmallow from one plus :)
  17. aj7400
    Ice Cream Sandwich Jan 3, 2016
    aj7400 , Jan 3, 2016 :
    Faced another bug...
    When i deactivate or activate my second sim , from sim cards option in settings,
    My op2 hangs for 6-8 seconds,
    If i try to pull notification bar down, it takes 6 seconds to respond
  18. wmm
    KitKat Jan 3, 2016
    wmm , Jan 3, 2016 :
    As far as I know, the only solutions are either to use a different launcher or to wait for the next update.
  19. Melancholie
    Melancholie , Jan 3, 2016 :
    After spending a bit more time with the update, I started to notice that one of my apps was using a LOT of battery. This didn't happen before the update, so I don't know why it is now. I've deleted that app and now the battery is incredible. Once I'd established battery was better without the app, I cleared cache and then reinstalled the app to see if it was just a glitch but as soon as I reinstalled it the battery drain started happening again. So the app is now gone. Gutted as it was an app I used on a regular basis. Is there an incompatibility issue between 2.2.0 and some apps?
    I've also noticed a new bug yesterday. Previous to the update, I could make and receive calls over the bluetooth hands free in my car. It didn't sync contacts and recent calls, which was annoying, but the calls themselves worked. Now, since the update, it doesn't work at all. The screen in the car shows it's connected and shows dialling and how long the call has been connected for, but the sound does not come through the car anymore so I have to actually hold the phone up to my ear. Yesterday was the first call I'd made since the update; I won't be able to use the phone in the car now. This is a serious bug which needs to be fixed a.s.a.p.
  20. Maria Pap
    Maria Pap , Jan 3, 2016 :
    Are you rooted or not? It can be done both ways
